Post by shandyboy on May 29, 2015 23:00:01 GMT 1
Bike stopped starting today,checked for spark and nothing there changed plugs still nowt Any ideas ? how do you check the coils ?? Anyone got a spare set I could buy Thanks Alan
Post by rsvr1000 on May 30, 2015 9:19:13 GMT 1
Not sure about checking coils but I had an issue with my 400D, ended up being a charging fault , points models need a fully charged battery to run and get a spark, have checked all wiring, connections, fuses? I think I have pair of coils in shed shall check after for you
Post by shandyboy on May 30, 2015 12:09:03 GMT 1
Cheers Tony Iam about to try a old coil of my 350LC looks the same wiring, also been told a X7 coil will work too as its a single coil with two HT leads coming off it. THE JOYS OF TWO STROKES !!
Post by muttsnuts on May 30, 2015 15:50:27 GMT 1
its more likely your pickup coil that has gone, test it with a meter, should read 87 ohms +/- 10% at 20 degress, also check your stator windings (low/high ignition coils), also don't forget about the cdi, could be that as well
the E and F models will run with a flat battery, the C/D models won't
HTH
Post by Tone on May 30, 2015 16:59:22 GMT 1
Have you checked the basics like kill switch is in the run position and ignition switch is ok.
Post by shandyboy on May 30, 2015 19:22:51 GMT 1
Yup checked ignition and kill switch there good, will try and check low/high side on coil CDI is there any test ??
Post by rsvr1000 on May 30, 2015 19:32:20 GMT 1
Cheers Tony Iam about to try a old coil of my 350LC looks the same wiring, also been told a X7 coil will work too as its a single coil with two HT leads coming off it. THE JOYS OF TWO STROKES !! Have found a pair of coils , let me know if you still need some
Post by shandyboy on May 30, 2015 20:53:39 GMT 1
sound mate will give you a shout if I need them
Thanks Alan
Post by 4ce on May 31, 2015 22:12:05 GMT 1
C-D model has two separate coils, E-F has one the same as LC model.
Post by shandyboy on Jun 2, 2015 18:34:20 GMT 1
Update on no spark on bike, checked everything and fitted a spare LC coil still no spark?? fitted original coil back and rested plugs on cylinder head to check for spark and still nothing ? so put the plugs back in kicked it over and to my amazement the bike starts and runs ??
However when I take the plugs back out and check for spark nothing?? put them back in bike and it starts and runs ?? Hows that ??
Post by arrow on Jun 2, 2015 20:53:13 GMT 1
These bikes are quite well known for not having a very good spark. Try it when it gets a bit darker and you should see it. And remember you need both plugs connected and earthed at the same time for the system to work.
Post by shandyboy on Jun 2, 2015 22:59:35 GMT 1
Will give it a try mate
