Post by looey on May 26, 2015 10:41:17 GMT 1
Quick question.....
Is it possible to replace the neutral switch on a YPVS 350 engine without draining the gearbox oil or major oil loss whilst doing so ?.
Cheers
Post by markhoopy on May 26, 2015 11:03:50 GMT 1
Quick question..... Is it possible to replace the neutral switch on a YPVS 350 engine without draining the gearbox oil or major oil loss whilst doing so ?. Cheers Yes - hardly any oil comes out, and if you lean your bike against a wall on the right handlebar it is easier to do the job and no oil loss at all too.
Post by looey on May 26, 2015 13:44:12 GMT 1
Cool, ta. Makes you wonder why they leak so much when just one screw area is cracked ?
Post by markhoopy on May 26, 2015 13:58:12 GMT 1
There must be an oil feed in there to lubricate the selector drum at that end and the oil will be under pressure when the engine is running I suppose. An easy fix though, as is the gear lever shaft seal which can be changed with the bike leant over without any oil loss in just the same way.
Post by stusco on May 26, 2015 18:29:29 GMT 1
What a coincadince just got my new one from norbo going on tonight
Post by bare on May 27, 2015 4:56:00 GMT 1
Neither oil feed nor pressure. Oil simply seriously thins with Temp.. and the swill subsequently travels everywhere.
Post by looey on May 27, 2015 9:02:09 GMT 1
What a coincadince just got my new one from norbo going on tonight Let us know how you get on, collecting mine from my local Yam dealer in a minute
Post by The Pirate on May 27, 2015 11:05:43 GMT 1
What a coincadince just got my new one from norbo going on tonight Let us know how you get on, collecting mine from my local Yam dealer in a minute must be the week for replacing them,, ive got one awell to fit on the ypvs,, hope a dont crack it with the bolts.. as is the gear lever shaft seal which can be changed with the bike leant over without any oil loss in just the same way. whats the best way to get this seal out without removing the shaft,,,, ive got a replacement but didnt want to just gouge it out, just incase the new one dont fit, (unlikely but you never know)
Post by markhoopy on May 27, 2015 15:31:38 GMT 1
Post by stusco on May 28, 2015 15:06:55 GMT 1
What a coincadince just got my new one from norbo going on tonight Let us know how you get on, collecting mine from my local Yam dealer in a minute Just fitted mine lent the bike against the wall of my garage never lost any oil
