Post by kostas on May 22, 2015 22:07:22 GMT 1
Was thinking that the finish on my refurb switchgear is good but not close to original. I used stickers and clear coat over.
Has anyone ever tried to transfer Letraset Letters on the switch and the paint clear over? Should give a pretty good result, given that the letter is very thin..
Kostas
Post by midlifecrisisrd on May 23, 2015 10:40:02 GMT 1
Worth a try. Would make sure it does not react to dissolve in the clear coat.
Was the reason I ended up buying nos ones
dezcbr
Post by dezcbr on May 23, 2015 11:06:49 GMT 1
Letraset do/did their own spray on stuff for protecting letters etc. we used it at work when we still used drawing boards
Post by kostas on May 23, 2015 13:25:20 GMT 1
On their website it states that using polyurethane clear coat it does not affect the letters. I will give this a try as I think it will give a very close to original finish
Post by bare on May 25, 2015 17:12:02 GMT 1
Certainly try it? I did once to a Favourite Keyboard that I wore out the letters on. Applied Polyurethane clear as cover over the Bits of Letraset (where would you even get that stuff these days, It's been extinct for years, has it not?) figuring it would be a tough coating. Wore off within a week. G'luck.
Post by kostas on May 26, 2015 15:18:36 GMT 1
Certainly try it? I did once to a Favourite Keyboard that I wore out the letters on. Applied Polyurethane clear as cover over the Bits of Letraset (where would you even get that stuff these days, It's been extinct for years, has it not?) figuring it would be a tough coating. Wore off within a week. G'luck. Within a week!! That's not good.. They are not extinct, you can get those thru Letraset (brand name) and cost the that 5 euro including mail from France.
Post by JonW on May 26, 2015 23:57:31 GMT 1
you hit the keys a lot more than you you would switchgear words, I reckon you might well be ok with it if you do it, will be fiddly tho to get it lined up, Letraset was always thus LOL
