horace
Post by horace on May 10, 2015 17:32:04 GMT 1
Anyone no how to take it off f2 type speedo. Thanks.
Post by alastairh on May 25, 2015 14:43:12 GMT 1
If it has a knurled type end like this RD125 Mk2/3 or TZR125 there is a small phillips screw which goes up the centre of the spindle. Look on the round end you should see a hole in it. You'll need something like a small watchmakers screw driver to get it out.
Post by alastairh on May 25, 2015 14:55:52 GMT 1
Try this better photo.
Post by JonW on May 26, 2015 23:59:13 GMT 1
Not sure about the F2, but some of these knobs also unscrew, left handed thread i think. the issue is holding the rod while you do it, if you can put something like a blunt screwdriver down the hole it may help.
Post by midlifecrisisrd on May 27, 2015 11:36:48 GMT 1
Not sure about the F2, but some of these knobs also unscrew, left handed thread i think. the issue is holding the rod while you do it, if you can put something like a blunt screwdriver down the hole it may help. Done about half a dozen and were all reverse threaded. As you say stich a jewelers screwdriver down the hole to give some resistance. Most were not tight but had one I had to remove the face and get a pair of long nose pliers at it Steve
Post by alastairh on May 27, 2015 12:35:19 GMT 1
Not sure about the F2, but some of these knobs also unscrew, left handed thread i think. the issue is holding the rod while you do it, if you can put something like a blunt screwdriver down the hole it may help. I think the later ones have the screw down the centre. The 250/350LC's screw on if memory serves me correctly.
Post by JonW on May 27, 2015 13:49:33 GMT 1
Ive also had one that I had to grip with pliers, once Id part stripped the unit out of the case, thing spun off easy as pie with them holding it too.
