Post by stusco on Apr 21, 2015 17:01:29 GMT 1
Anyone got a picture of their Tarozzi rearsets fitted with a metmachex swingarm on a 4l0 rear brake side,if so did they use spacers as I don't seem to have enough room for the linkage pivot it hits the swingarm!!!
Post by Trubrit on Apr 21, 2015 17:11:45 GMT 1
Pretty Sure When I Fitted Gearys New Arm Had To Space The Rearsets Off By 10mm
Post by Trubrit on Apr 21, 2015 17:17:18 GMT 1
Post by stusco on Apr 21, 2015 17:33:02 GMT 1
Thanks I'll get the washers oot to mock up
Post by steeley on Apr 22, 2015 5:20:25 GMT 1
my mate gordi had a 350lc with a metmachex swing arm and his rearsets were spaced out about 10mm.
Post by stusco on Apr 22, 2015 7:39:28 GMT 1
Got 10 mm off washers in just know but one of the pivot arms hit the frame so will need to fine tune it mah need to bend the arm slightly it's only for the brake switch
Post by lcyoungboy on Apr 22, 2015 8:51:31 GMT 1
Got 10 mm off washers in just know but one of the pivot arms hit the frame so will need to fine tune it mah need to bend the arm slightly it's only for the brake switch I know what you mean..they are a right pain..I couldn't bend mine..so I grinded the top off the bracket till it cleared the frame..works grand now
Post by stusco on Apr 22, 2015 16:14:24 GMT 1
Got lucky today my first job was in a machine shop so got one of the guys to knock up a couple of spacers ,only took a fiver ,result
Post by stusco on Apr 22, 2015 16:52:42 GMT 1
Now the other one hits the frame it's getting ground only needs a bahair
