Post by Topman350 on Apr 20, 2015 10:16:26 GMT 1
Post by 4l04ever on Apr 20, 2015 11:09:15 GMT 1
The bike looks a bit high at the back....you need a smaller piece of wood to lower it a bit :-)
Regarding the tank, it looks okay from the back, but from the side, the gap underneath looks too big.
Post by dllc on Apr 20, 2015 11:31:59 GMT 1
would agree with 4lo4ever the gap between frame and tank doesn't look the best, the rest of it looks 100% what sub frame did you use?
Post by Topman350 on Apr 20, 2015 13:36:56 GMT 1
Lol the wood isn't the issue with the height as I can lower the sub frame the gap on the tank can be sorted too just toying with it for now the sub frame is MVF3 cheers guys :-)
Post by anyoldiron on Apr 20, 2015 15:15:33 GMT 1
Not without a lot of work to the underside to narrow the tank and make it fit, no.
Post by Topman350 on Apr 20, 2015 16:15:05 GMT 1
More pics to follow soon
Post by jackjabba on Apr 20, 2015 17:41:25 GMT 1
Is that the Gilera / Derbi tank? Are the wheels Ozz or the Derbi copies?
Post by Topman350 on Apr 20, 2015 20:04:06 GMT 1
Is that the Gilera / Derbi tank? Are the wheels Ozz or the Derbi copies? Yes mate Derbi tank easy to alter as it's plastic front wheel 2013 blade rear cb500r same design :-)
yamrider
its not where you are its where you want to be
Post by yamrider on Apr 22, 2015 20:25:19 GMT 1
I like the build it should look mean when it is finished
Post by iwantalc on Apr 22, 2015 20:58:46 GMT 1
fat back tyre looks well
Post by Topman350 on Apr 23, 2015 0:18:57 GMT 1
Post by Topman350 on Apr 23, 2015 0:25:14 GMT 1
Close up of the mounting points for the subframe I've worked out how to sort the lower connections pic will follow when completed :-)
Post by fozzy17 on Apr 23, 2015 7:03:42 GMT 1
looking good fella.
Post by Topman350 on Apr 23, 2015 20:10:05 GMT 1
Post by rigga on Apr 23, 2015 21:33:05 GMT 1
Excellent progress, this could be a stunner again.
Post by Topman350 on Apr 23, 2015 23:56:27 GMT 1
Excellent progress, this could be a stunner again. Thanks mate hope my ideas pay off as my 1st build for me was the bench mark :-)
2taol
Post by 2taol on Apr 24, 2015 14:29:54 GMT 1
really like that! different hardware used than the normal hybrid stuff.
Post by Topman350 on Apr 25, 2015 20:29:08 GMT 1
really like that! different hardware used than the normal hybrid stuff. Thanks mate I'm trying to be different in the parts I'm using, want to create another special :-) the finished look I have in my head is really cool hope it's turns out like I imagine hard work though Cheers Topman
Post by Topman350 on Apr 25, 2015 20:42:14 GMT 1
Not without a lot of work to the underside to narrow the tank and make it fit, no. Yes mate a lot of work the other issue is where the tank meets the rear plastics to flow right these builds are never easy ill get there chap :-)
Post by Yogi on Apr 25, 2015 20:44:13 GMT 1
You've already raised the bar high Your even finding it hard to compete with yourself Keep up the good work mate, coming along pukka
Post by Topman350 on Apr 26, 2015 22:20:09 GMT 1
You've already raised the bar high Your even finding it hard to compete with yourself Keep up the good work mate, coming along pukka Hi buddy your right there got my work cut out with this one loving the challenge fella will keep adding pics as I go along :-)
Post by Topman350 on May 8, 2015 20:14:12 GMT 1
Trying to sort out the top shock mount with regards the shock itself from an MVF4 looks ok but for some reason not 100% happy so I've ordered one from an RSV4 which I think will sit a lot better my clip ons came and the 999 master cylinder I will sell on the MV shock if anyone wants it £165 bargain
Post by jon on May 9, 2015 9:11:46 GMT 1
Looking good so far.
Have you mounted your clipons upside down?
Post by Topman350 on May 9, 2015 18:03:10 GMT 1
Looking good so far. Have you mounted your clipons upside down? Yes mate I have for a more retro look did it with my last one too, The pics for the shock mount I've will have to wait until photo bucket stops pissing about with free ads it's a right nuisance Cheers
Post by jon on May 10, 2015 7:49:07 GMT 1
Have you checked your chain run yet?
I assume your wheel is 17" x MT4.5 with a 160 tyre?
I am testing my first choice of wheel in the hybrid I am building of exactly the same sizes, and the chain run is tight to clear the tyre and frame.
Post by dono on May 10, 2015 18:31:27 GMT 1
That's Talent if I ever saw it mate
Post by Topman350 on May 14, 2015 1:59:04 GMT 1
Have you checked your chain run yet? I assume your wheel is 17" x MT4.5 with a 160 tyre? I am testing my first choice of wheel in the hybrid I am building of exactly the same sizes, and the chain run is tight to clear the tyre and frame. Hi buddy sorry for the late reply...I've checked the chain run and I've ordered an offset front sprocket from nk racing £35 del it's a 17t 9mm offset does the job good luck with yours chap :-)
Post by Topman350 on May 14, 2015 2:01:05 GMT 1
That's Talent if I ever saw it mate Much appreciated mate I'm hoping to upload more pics on soon :-)
Post by mercwagonman on May 17, 2015 20:52:58 GMT 1
Looks great...more pics please
Post by Topman350 on May 17, 2015 22:00:21 GMT 1
Pic's of my rear and shock link starting to take shape
