Post by iwantalc on Apr 15, 2015 19:14:12 GMT 1
what engine oil would you recomend for a 350 ypvs engine thanks
Post by skydemon on Apr 15, 2015 19:25:41 GMT 1
Age old question. It's all good stuff these days and miles better than our bikes were designed for LOL. F@ck me lawnmower oil is better than what we had back in the day ?
Post by iwantalc on Apr 15, 2015 19:31:22 GMT 1
ok thanks what i should of asked is what is the correct oil for a 350 ypvs as in grading ie for a car 5w 30 10w 40 ect thanks
Post by steeley on Apr 15, 2015 19:42:04 GMT 1
hi,i use 5w 30 in my lc 350 and its done me well easy gear change and easy to find neutral .
Post by iwantalc on Apr 15, 2015 19:51:59 GMT 1
do you think the same grading is ok for a ypvs engine thanks
Post by skydemon on Apr 15, 2015 20:06:23 GMT 1
Castrol TTS or Motul 710 are the favourites
Post by iwantalc on Apr 15, 2015 20:09:59 GMT 1
thanks for replys..piss takers thats why i asked the question
Post by looey on Apr 15, 2015 20:35:12 GMT 1
thanks for replys need to change oil so think i will go for castrol tts Is that 5w/30 TTS ?....
Post by arrow on Apr 15, 2015 20:38:29 GMT 1
thanks for replys need to change oil so think i will go for castrol tts TTS is 2 Stroke oil matey.
Post by looey on Apr 15, 2015 20:42:02 GMT 1
thanks for replys need to change oil so think i will go for castrol tts TTS is 2 Stroke oil matey. I thought he might get that from my post
Post by iwantalc on Apr 15, 2015 20:46:33 GMT 1
asking the question cos didnt know what oil was what glad you found it so funny ..
Post by bare on Apr 16, 2015 3:29:02 GMT 1
Trans case oil?? GL4 Gear oil Is Ideal. Prevents ;finding N issues' as the engine warms.
higgsy
Post by higgsy on Apr 16, 2015 4:56:27 GMT 1
I think the TTs is called power one these days. I've used Motul Trans oil and Silkolene Light in the gearbox, both work without any issues, but the race bikes, both YPVS and TZr, do have beefed up clutches. The TZr is now on ATF which gives a light lever and no slip but I'm not sure how that would work out on a road bike doing a lot of miles, it's quite thin
Post by steeley on Apr 16, 2015 7:33:56 GMT 1
I wouldn't use atf oil, as higgsy said it is thin stuff.i used it years ago in my rgv and it was quite silvery when I dropped it out to do an oil change .
higgsy
Post by higgsy on Apr 16, 2015 7:36:14 GMT 1
Yea that would be the worry, doesn't matter on the TZR as the motors come apart regularly and the gearbox bearing changed, no noticeable wear on the bikes that have run it for a while but I wouldn't on a road bike
