Post by pistanbroke on Mar 18, 2015 16:31:20 GMT 1
Hi Guys , just charged up the battery on the hybrid, all electrics working fine apart fae the indicators flash slowly, took out the flasher unit , 3 pin, and fitted the 3 pin one outa my other 4lo( works fine on that bike) but no flashing at all then , buggeration lol, any ideas?? Cheers in advance as electrics aint ma thing at all
Post by raven13 on Mar 18, 2015 21:39:37 GMT 1
are you using led or low wattage indicators on the hybrid??? if so you will need a different relay
Post by shaunthe2nd on Mar 18, 2015 21:45:41 GMT 1
check that all 4 indicator bulbs are the same rating too
Post by pistanbroke on Mar 18, 2015 23:13:29 GMT 1
Standard indicators at the moment, i'll check the bulbs first then Shaun, cheers guys
Post by Yogi on Mar 18, 2015 23:51:51 GMT 1
check that all 4 indicator bulbs are the same rating too I've had this problem before and found one bulb was wrong, if all else fails take em off and use your hands,,Lol
Post by pistanbroke on Mar 19, 2015 10:57:32 GMT 1
Checked all four bulbs, all are the correct 21w bulbs , damn lol, the writing on the flasher relay has worn off so don't know if its a standard one or not, the standard flasher relay in my other LC wont flash the hybrids indicators at all which is strange, only other thing I found was I have 2 new (pattern) indicators on the right side of bike and 2 original indicators on the left side, the buld holders on the older ones are a bit rusty, ive cleaned em up best I could but made no difference, the newer ones don't flash any faster anyway, hmmmm. What about the bulbs in the instrument cluster if they were wrong would that make a difference ? they are meant to be 3.4w , cant see them causing an issue but could be wrong , cheers in advance guys
Post by pistanbroke on Mar 20, 2015 0:05:16 GMT 1
Should I try a different relay guys??
Post by raven13 on Mar 20, 2015 0:55:52 GMT 1
couldn't hurt
Post by Gitram on Mar 22, 2015 9:48:38 GMT 1
bad earth somewhere? have you tried swapping indicators with your other bike?
Post by pistanbroke on Mar 22, 2015 11:15:15 GMT 1
bad earth somewhere? have you tried swapping indicators with your other bike? Trying that today , will report back later , thought about a bad earth too, tried a 2 pin relay I had lying about and it flashes correctly now but the bulbs aint very bright now. Probably need to clean up the earth points as well .
Post by pistanbroke on Mar 23, 2015 23:45:42 GMT 1
Right swapped over the indicators and relay and all worked well so that ruled out a wiring fault,so I changed all the bulbs for new and fitted a new relay , still no as bright as id like but flashing properly now . Think i'll spray the inside of ra indys silver to brighten em up a bit.
