Post by pistanbroke on Feb 26, 2015 19:16:45 GMT 1
Hi lads, wanna pick the brain of you guys that have fitted the clear clutch cover, in the fitting instructions from NK Racing he says to brush on a oil /petrol proof sealant in the o ring groove on the clear window, I assume if its brushable that it needs to be quite liquid if that makes sense, what you guys use as I cant think what to use Thanks in advance
Post by Deleted on Feb 27, 2015 10:11:53 GMT 1
why does it need to be petrol proof?
shouldn't have petrol in the gearbox
A good reasonable temp rated RTV gasket silicone will do (except Blue Max or Ultra Blue/Grey or whatever colour you can get-they dissolve in oil)
I'd use either a black or clear, black if your side case is black or clear cause the cover is clear
Post by pistanbroke on Feb 27, 2015 17:21:14 GMT 1
Cheers mate I will go have a look in ma garage sure ive got some
Post by huggy76 on Feb 28, 2015 13:51:09 GMT 1
I've made some clear covers in the past and have used an o ring dry, they have been fine and don't leak.
Post by carioca656 on Feb 28, 2015 18:07:27 GMT 1
hi huggy have you still got some if so how much
adie
Post by pistanbroke on Mar 1, 2015 13:30:10 GMT 1
Used a clear RTV instant gasket, worked fine , cheers lads
Post by huggy76 on Mar 1, 2015 16:38:38 GMT 1
Adie, PM sent
