Post by fozzy17 on Feb 24, 2015 12:27:11 GMT 1
Bought a 31k yesterday and its blowing from the microns, before I strip it is there anyone who can tell me what I need to change that gasket set or oring, any advice or where I can get them would be a help.
Post by 4l04ever on Feb 24, 2015 13:06:37 GMT 1
They are usually just the standard copper ring gaskets - with some high-temp silicon to seal. The end of the exhaust has a double skin which goes over the flange (ooooo eeerrr missus) this also needs some silicon on it. Leave the silicon to go off overnight and cross your fingers :-)
Post by fozzy17 on Feb 24, 2015 13:59:51 GMT 1
They are usually just the standard copper ring gaskets - with some high-temp silicon to seal. The end of the exhaust has a double skin which goes over the flange (ooooo eeerrr missus) this also needs some silicon on it. Leave the silicon to go off overnight and cross your fingers :-) ive got some rd500 copper rings I think they are the same, I noticed two springs on the headers is there a gasket in there maybe a fibre ring? oeer
Post by 4l04ever on Feb 24, 2015 14:13:30 GMT 1
No gasket where the springs attach.
Post by bare on Feb 26, 2015 4:43:31 GMT 1
Shouldn't blow from the slip joint. Welll at least nothing that can't easily be rag wiped off after a ride. Maybe your new pipes are full of cooked oil? Repack the End cans as a start.
Post by fozzy17 on Feb 26, 2015 7:43:48 GMT 1
the bike hasn't been run since rebuild, will pull them apart for a look
Post by pistanbroke on Feb 28, 2015 10:25:26 GMT 1
I had Microns that were blowing like that an aw Fozzy, dont use the oval Gasket just the copper ring type, I used some fire rated black silicon sealant for stoves etc from a local hardware store as well, worked a treat
Post by fozzy17 on Feb 28, 2015 10:35:31 GMT 1
I had Microns that were blowing like that an aw Fozzy, dont use the oval Gasket just the copper ring type, I used some fire rated black silicon sealant for stoves etc from a local hardware store as well, worked a treat ohh ive got some of that here fire cement?
Post by stusco on Feb 28, 2015 11:27:39 GMT 1
I don't think he means fire cement I think he means high temp silicone
