Gear oil
Feb 23, 2015 10:18:19 GMT 1
via mobile
Post by yazza54 on Feb 23, 2015 10:18:19 GMT 1
This has no doubt been done to death but have tried a search with no luck.
What gear oil should I use in my 443 cheetah cub? Heard people run ATF or just normal 10w30 bike oil?
Post by arrow on Feb 23, 2015 11:43:15 GMT 1
Bare on here says use 75/80 gear oil to GL4 spec. Its the best I have ever used. Wet clutch safe too. Gear oils are rated different to engine oils. 75/80 gear oil is like 10/40 engine oil.
Post by tippo on Feb 23, 2015 19:40:57 GMT 1
I use Silkolene light gear oil in my LC gearboxes
Post by dllc on Feb 23, 2015 21:02:35 GMT 1
yep gear oil all the way
Gear oil
Feb 23, 2015 21:43:12 GMT 1
via mobile
Post by Delbert on Feb 23, 2015 21:43:12 GMT 1
Bare on here says use 75/80 gear oil to GL4 spec. Its the best I have ever used. Wet clutch safe too. Gear oils are rated different to engine oils. 75/80 gear oil is like 10/40 engine oil. +1 Same for me
Post by 4l04ever on Feb 24, 2015 13:02:01 GMT 1
ATF in my bikes now :-)
Post by yazza54 on Feb 24, 2015 13:14:29 GMT 1
Bought some comma 75/80 gl4 thanks arrow
Gear oil
Feb 25, 2015 13:33:15 GMT 1
via mobile
Post by Deleted on Feb 25, 2015 13:33:15 GMT 1
Hi guys, haynes says to use 10/30 for my 250lc but I can't seem to find it anywhere locally. Should I use 10/30 engine oil or a gearbox oil like your talking about? Thanks
Post by raven13 on Feb 25, 2015 14:38:42 GMT 1
always a gearbox oil for me, silkolene light gear oil
Post by wallcraft on Feb 26, 2015 9:40:05 GMT 1
Atf in mine
Gear oil
Feb 26, 2015 14:28:48 GMT 1
via mobile
Post by Deleted on Feb 26, 2015 14:28:48 GMT 1
always a gearbox oil for me, silkolene light gear oil Found a Motul Transoil medium, same rating as 10w30 as Haynes says but it's the equivalent in gear oil, will that be alright?
Post by arrow on Feb 26, 2015 14:42:15 GMT 1
always a gearbox oil for me, silkolene light gear oil Found a Motul Transoil medium, same rating as 10w30 as Haynes says but it's the equivalent in gear oil, will that be alright? The Motul transoil is another excellent product. Use with confidence.
Post by raven13 on Feb 26, 2015 17:04:29 GMT 1
I'll agree with anything Arrow says. when it comes to engine lubrication he is the oracle of all knowledge
Post by Deleted on Feb 26, 2015 23:48:16 GMT 1
Lovely, will be ordering some of that then! Thanks guys
