Post by spooch63 on Jan 31, 2015 15:36:45 GMT 1
Hi all, latest project is rusty to say the least, and all nuts, bolts fixings etc are going to need a good soaking in order to release them without snapping the heads off, I usually use WD40 but was wondering if there was anything else out there that would give better results.
Cheers
Post by reggieperrin on Jan 31, 2015 15:57:30 GMT 1
My favourite c**ktail that never fails to release stuff is;
40% Auto transmission fluid 40% Thinners 20% Diesel or paraffin
Give it a shake before use as it settles. Obviously, with the thinners in the mix, careful what you use it on...
Post by spooch63 on Jan 31, 2015 16:04:49 GMT 1
My favourite c**ktail that never fails to release stuff is; 40% Auto transmission fluid 40% Thinners 20% Diesel or paraffin Give it a shake before use as it settles. Obviously, with the thinners in the mix, careful what you use it on... When you say careful what you use it on, how do you mean, I'm assuming you mean paintwork.
Post by spooch63 on Jan 31, 2015 16:08:13 GMT 1
Won't be a problem with the paintwork on this project as there isn't any left on it
Post by marsbar350 on Jan 31, 2015 16:19:17 GMT 1
Post by steeley on Jan 31, 2015 18:44:12 GMT 1
yep that sounds like a good mix to me .
Post by spooch63 on Jan 31, 2015 19:03:52 GMT 1
Will mix up a brew on my next day off and we'll see how we get on with it
Post by steve h on Jan 31, 2015 22:53:42 GMT 1
KY jelly?
Sorry wrong end of the stick, plus gas or diesel.
Post by 4l04ever on Jan 31, 2015 22:55:06 GMT 1
Try PlusGas
Post by Tobyjugs on Jan 31, 2015 23:18:16 GMT 1
How about freeze and release by loctite. Personally i think it is rubbish and just a gimmick but some of my colleagues love it Still anything is better than an easyout!
Post by johna on Feb 1, 2015 1:24:30 GMT 1
50% atf 50% acetone also works well.
Post by tippo on Feb 1, 2015 9:09:44 GMT 1
Super slaks or Diesel for me. After that it usually involves some heat to prevent snapped bolts/studs.
Post by LC_BOTT on Feb 1, 2015 9:55:07 GMT 1
Also try hitting the heads first a few times before removing, this helps to shock the threads a bit, careful though if they are in alloy casings etc. Heat helps as well if you have access, although I've used a good heat gun with great results too. sorry if you know this already
Post by rigga on Feb 1, 2015 15:05:23 GMT 1
Don't know why people use wd40 as a releasing agent, as its a water displacer first and foremost, and is actually pants at freeing anything off as said plus gas works well, and the above home brew is a good mixture.
Post by spooch63 on Feb 1, 2015 17:06:44 GMT 1
I was thinking Plus Gas but can't seem to find any anywhere, a gentle tap with a hammer to shock the threads and the application of a little heat is the usual way I deal with these things. Usually apply a little heat before applying a freeing agent. Will see if i can't track down some Plus Gas and if not the home brew it is !!
Post by steeley on Feb 1, 2015 19:24:04 GMT 1
oh hold on ,wd40 don't you fisher men here spray it on your bait to attract the fish.if that's right its money well spent.oh the bloke who invented wd 40 sold it cheap because he thought he wasn't far from inventing some thing that would make him big money.doh, I think he died skint.
Post by andfist600 on Feb 1, 2015 23:19:05 GMT 1
Plus gas is a good one, but leave it overnight
Post by mentalist on Feb 2, 2015 9:42:52 GMT 1
Plus gas is a good one, but leave it overnight + 1, use this stuff offshore in the North Sea, where everything rusts!!!!
Post by Deleted on Feb 2, 2015 14:37:18 GMT 1
+1 on the Loctite freeze it,only works on small bolts in small housings
Try Wurth Rost Off,spray on and leave 10 mins
or heat it up then pour cold water on it does the same trick as the freeze it
+1 on the shock treatment too, a good impact driver will work
+1 on the c**ktails above they will all help too
Post by Deleted on Feb 2, 2015 14:37:55 GMT 1
Yield Nut Cracker is another good one, although it can be hexy
Post by oldelsieboy on Feb 2, 2015 16:00:31 GMT 1
Don't know why people use wd40 as a releasing agent, as its a water displacer first and foremost They sell a rust release/penetrating specific product OEB
Post by rigga on Feb 3, 2015 4:40:16 GMT 1
Very good, but mention wd40 to anyone and its the normal yellow and blue can they think of which is readily available and is not a releasing agent .....we get through tons of the stuff at work people spray it and wonder why the offending retaining nut/bolt still won't budge.
Post by zedixe13 on Feb 3, 2015 5:14:25 GMT 1
WD-40 is the crappiest of them all .
Post by JonW on Feb 3, 2015 9:21:55 GMT 1
Ive used ATF acetone, its ok actually, but will evaoprate if left with the lid off... in my my old chemist bottles it used to pop the stoppers... :/
