Post by kostas on Jan 27, 2015 20:33:35 GMT 1
I have an oil leak from the bottom of my carbs. I had new gaskets fitted and carbs were clean, my guess is that it is leaking fuel and as it evaporates the 2 stroke oil remains as a leak. Picture is not very bright How do I cure this?? could it be oil passing from the pump? Do you guys use any kind of sealer on the carb gasket? Thanks Kostas
