rd
Jan 24, 2015 9:15:37 GMT 1
via mobile
Post by jarvis on Jan 24, 2015 9:15:37 GMT 1
Front piston stuck how can I get it out please help
rd
Jan 24, 2015 9:19:02 GMT 1
jarvis likes this
Post by tippo on Jan 24, 2015 9:19:02 GMT 1
I guess you are talking brake caliper piston??. You can use compressed air where the banjo bolt is fitted or fit the master cylinder,bleed it and use hydraulic pressure pump it out
rd
Jan 24, 2015 10:59:47 GMT 1
jarvis likes this
Post by 1966baz on Jan 24, 2015 10:59:47 GMT 1
Or even try a grease gun on it, if you don't have access to compressed air. This can sometimes be quick and simple. Good luck.
Post by robin on Jan 24, 2015 11:34:18 GMT 1
grease gun worked for me, extremely messy to clean up afterwards, but the safest way, I tried air compressor before and still have the dent in the garage wall as evidence, piston flew out of the cliper like a rocket when it finally let go, grease gun was more controlled, but remember to keep your fingers out of harms way!
Robin
rd
Jan 24, 2015 17:31:41 GMT 1
via mobile
Post by jarvis on Jan 24, 2015 17:31:41 GMT 1
Thanks will try grease gun tomorrow ?
rd
Jan 24, 2015 17:35:04 GMT 1
via mobile
Post by jarvis on Jan 24, 2015 17:35:04 GMT 1
kjellg
rd
Jan 24, 2015 17:54:42 GMT 1
via mobile
Post by kjellg on Jan 24, 2015 17:54:42 GMT 1
is it a good or bad idea to clean the brake calliper in ultrasonic ? maybe it helps If piston is stuck in dirt or corrosion
rd
Jan 24, 2015 19:01:48 GMT 1
Post by steeley on Jan 24, 2015 19:01:48 GMT 1
I have got pistons out with compressed air before and you need a rag to catch the thing and your wits about you.i bought a caliper piston removal kit it fits most stuff and is safer.lazer I think or sealey .
rd
Jan 24, 2015 20:24:04 GMT 1
Post by liffy16 on Jan 24, 2015 20:24:04 GMT 1
have reassembled and used hydraulic pressure to move pistons before now .put toolmakers clamp over free pistons and pump out piston with master cylinder
rd
Jan 25, 2015 20:54:56 GMT 1
Post by spooch63 on Jan 25, 2015 20:54:56 GMT 1
Got mine out by getting a blow lamp on and around the piston, after a few minutes and some smoke got a pair of pliers on it and it came straight out, piston was knackered and new one came with seals so no issues about melting them.
