Post by oldelsieboy on Jan 22, 2015 15:50:31 GMT 1
Would like to purchase a new set of headlight brackets for my yellow 4L0-brid. Like the look of THESE but not available in the correct fork clamp diameter (44-45mm). Looking for recommendations on where find a supplier. TIA OEB
Post by ulsta on Jan 22, 2015 16:40:26 GMT 1
Could you not just machine them out to the correct diameter ? looks like there should be enough material on them.
Post by oldelsieboy on Jan 22, 2015 19:09:49 GMT 1
Could you not just machine them out to the correct diameter ? looks like there should be enough material on them. I couldnt machine them out as I do not have the technology or know how to do so & I'm sure that those that do would charge an additional large amount for the pleasure. OEB
Post by 4l04ever on Jan 23, 2015 0:22:58 GMT 1
Try NK Racing, as I think he has made some in the past.
Post by oldelsieboy on Jan 23, 2015 8:05:56 GMT 1
Try NK Racing, as I think he has made some in the past. Cheers Rob, but £150 is a bit over my budget OEB
richb
Member is Online
Post by richb on Jan 23, 2015 9:07:29 GMT 1
Hello OEB contact Mikee on the forum he made me a set for my RGV upside downers, real nice brackets, cannot remember how much they were but deffo a lot cheaper than Nigel's. Rich.
Post by oldelsieboy on Jan 23, 2015 9:33:09 GMT 1
Hello OEB contact Mikee on the forum he made me a set for my RGV upside downers, real nice brackets, cannot remember how much they were but deffo a lot cheaper than Nigel's. Rich. Cheers Rich, will send him a message. Do you have any pics of your brackets? OEB
Post by ulsta on Jan 23, 2015 9:43:51 GMT 1
Could you not just machine them out to the correct diameter ? looks like there should be enough material on them. I couldnt machine them out as I do not have the technology or know how to do so & I'm sure that those that do would charge an additional large amount for the pleasure. OEB If you don't have access to a lathe then just use a half round file. You're only needing to take 0.5 to 1mm off, and its only headlamp brackets, you don't need absolute precision.
richb
Member is Online
Post by richb on Jan 23, 2015 10:31:27 GMT 1
Post by oldelsieboy on Jan 23, 2015 10:39:47 GMT 1
Cheers Rich, they look ideal OEB
Post by dusty350 on Jan 23, 2015 16:19:34 GMT 1
Hi Nigel, I got mine from M&P; Dusty
Post by oldelsieboy on Jan 23, 2015 16:25:01 GMT 1
Post by dusty350 on Jan 23, 2015 17:01:41 GMT 1
Hi Nigel Mine were £60.00 from M&P. The black ones in your link look good value. I've got some thin rubber you could use between the clamps and the forks if you did get them Dusty
Post by Tobyjugs on Jan 25, 2015 11:27:11 GMT 1
I am also searching for the same parts the brackets from mikee look good.
Post by dllc on Jan 31, 2015 23:19:26 GMT 1
any idea on cost of brackets from mikee?
Post by Tobyjugs on Jan 31, 2015 23:25:39 GMT 1
any idea on cost of brackets from mikee? Pm him
Post by oldelsieboy on Feb 1, 2015 0:00:57 GMT 1
any idea on cost of brackets from mikee? He can supply 2 types & quoted me £70 & £90 OEB
Post by andfist600 on Feb 2, 2015 22:06:08 GMT 1
Mikee's ones look pukka, I was put onto him from the guy on 2smoked site.
He quoted me Approx £100 to make a set up (3 days ago)
Post by JonW on Feb 2, 2015 22:43:06 GMT 1
Looks like without being here Ive already given 2 votes to Mike, and here is a 3rd... As yes, I love my headlight brackets and he did a great job and much cheaper than the other options if you want the CNC look.
I like the look of Dusty's M&Ps, but Ive never seen them on their site. Are they CNC alloy Dusty? tho its probably a moot point if they dont sell em anymore. :/
Post by Tobyjugs on Feb 3, 2015 10:36:35 GMT 1
He quoted me Approx £100 to make a set up (3 days ago) He quoted me the same price as well but i am happy with that, did not know that there were two types. I guess OEB get's discount for all the helpfull posts and long service etc etc!
Post by dusty350 on Feb 3, 2015 13:43:08 GMT 1
Hi My headlight brackets were from M&P Direct and cost £59.99. They are described as "Polished alloy streetfighter custom projector headlight brackets" ! The M&P code is 599528 if that helps. I bought some 5mm rubber sheet and cut thin strips to wrap around the polished fork legs before clamping the brackets on, both to take up a bit of slack and also protect the legs, and give the headlamp some damping. I am really pleased with them and they are well made and strong. Dusty
Post by dusty350 on Feb 3, 2015 13:46:56 GMT 1
Still on their website when I looked today, although the picture wasn't coming up for some reason Dusty
Post by andfist600 on Feb 3, 2015 21:30:51 GMT 1
He quoted me Approx £100 to make a set up (3 days ago) He quoted me the same price as well but i am happy with that, did not know that there were two types. I guess OEB get's discount for all the helpfull posts and long service etc etc! No, I didn't know there were 2 types, I'll ask him when I speak to him next
Post by oldelsieboy on Feb 3, 2015 21:41:26 GMT 1
Type 1 are a split version which can be fitted without removing the top yoke. Type 2 are similar but are a solid ring that fits around the fork leg & requires the top yoke to be removed. HTH OEB
Post by andfist600 on Feb 4, 2015 20:52:08 GMT 1
Thanks OEB, that helps, I'll mention that when I order some.
Cheers
Post by mikee on Feb 5, 2015 19:14:03 GMT 1
Unfortunately I've had to buy mor material science OEB enquired , hadn't realised how much it had risen To put you in the picture
The split clamp brackets compose of 10 machined pieces , the billet for the split clamps , 8 parts is £8.62 a bit + vat + delivery The sheet for the headlamp brackets is £68 or a 1m x.5 m bit , enough to do 20 brackets plus vat and del
Add the overheads software cutters and machining time and you get the picture
OEB enquired , then never came back , I guess I was too expensive for him , his loss Mike
Post by oldelsieboy on Feb 5, 2015 19:21:39 GMT 1
OEB enquired , then never came back , I guess I was too expensive for him , his loss Mike Or maybe I was waiting for an answer to the anodising question OEB
