Post by JonW on Jan 22, 2015 12:36:09 GMT 1
Ive asked this on the RDRZ500 forum as well as the owner of this bike frequents that site, but not everyone from here goes there, so ive posted it here for ideas, Im stumped
Ok, this isnt my bike, its local boy James'... I know everyone says bikes with issues are not theirs, but really this time its not mine... :smt016
Japanese N2 250.... started having an issue about 6months back that when riding it would die and immediately come back at about 8000 revs, when it did it looked like the tach died as did the rest of the electrics running the motor, as it felt like the whole bike died. Seemed to clear itself and then a few thousand kms later it did it again, cleared itself and was ok again for a bit, and repeat... but it got worse to the extent that it just kept dying and finally gave up the ghost only 100m from my house with what looked like no spark. We did manage to get a spark on occasion but it was weak and small.
We cleaned the plugs and some connections and it worked again enough to get him home 10km from my house, but it was a horrible ride up there with it dying and coming back. he found that flipping the kill switch seemed to allow it to fire back up (the bike was doing 100kph at the time so the motor fired back up as it was being spun by the back wheel etc).
At his house we found the loom was a mess, the coil lead connections were dirty and a bunch of other things, and he started a clean up and repaired the loom, but nothing seemed to fix the issue...
he tried:
- swapped the CDI for another one - its a 3HM, anyone know issues with those?
- bought a brand new OEM coil incl leads ($$$)
- fitted new caps
- changed the plugs
Still did it, but now it started and seemed to sound crisper, as all those things improved the spark of course.
Then he got another stator and swapped that and now it dies at about 2500... oops... we felt he was making progress as thats the first thing he did that had any effect, even tho it was worse.
He then fitted another loom as we felt it was connection related and his old one was really horrible... it wasnt an exact match but it was close... he set about making it work and isolating things and just using the simplest of circuits.
Now the kill switch and ignition are NOT attached so we know its not them.
Still does it... sigh...
Bike starts on the button now, but even on fast idle you can hear it reach about 2500 and then cut and come back, its like a rev limiter... weird.
I dropped up there today and we pulled the flywheel off again and I could see the crank and the flywheel had rust on the tapers. we cleaned that up and put it back on. I really thought we might have found the problem with this, it was really gross. but no.... Grrrr! :smt013
Since we had a quick before n after we could tell the bike is sprightlier again, and maybe a little better but it still does it... idle, cut, idle, cut etc.... totally unrideable as it cuts totally dead on even the faintest of throttle.
So... with most things replaced now and a lot of $$ spent, hes thinking of having his stator rewound and buying another flywheel as hes been told they go bad... tho ive never heard of that, its a bunch of magnets... can it really go bad?
Does anyone have any ideas? Is there any kind of stator test he can do to prove the ones he has are duff?
And... in full Sherlock Holmes mode, (once youve excluded the obvious, the bizarre may well be the answer etc) Could this even be unrelated to the electrical system and actually be carbs?
I dont often shrug and think, 'thank fek this one isnt mine...' but wow, its a tough one... thank fek it isnt mine! :smt037
(hopefully James will add to this, as maybe Ive forgotten some of the things hes done...)
Cheers guys!
he tried:
- fitted new caps
- changed the plugs
Cheers guys!
