tezrhc
Post by tezrhc on Jan 5, 2015 20:17:36 GMT 1
Hello LC crazy people,I want to fit the NC29 swingarm to the LC frame,the easy option is to get the swinger modded,but I would like to widen the frame and use the rising rate linkage. Has anybody done this or looked into it? Your input would be greatly appreciated.
tezrhc
Post by tezrhc on Jan 5, 2015 20:19:24 GMT 1
tezrhc
Post by tezrhc on Jan 5, 2015 20:23:20 GMT 1
Post by botty on Jan 5, 2015 20:39:11 GMT 1
Didn't think you were going to get started on this one yet?? LOL.
Type nc29 into the search option.a few links will come up. Have a look there.
Just had another look through the posts. Not going to be much help. Nobody seems to have used the linkage. KN Racing conversion.
tezrhc
Post by tezrhc on Apr 17, 2015 18:33:30 GMT 1
Well I've got the grinder out and cut the swingarm mounts off
tezrhc
Post by tezrhc on Apr 17, 2015 18:39:55 GMT 1
Next I have to make some new mounts big enough to take the 30mm thread. Cut out some templates from cardboard and stick them on with sticky back plastic. ?
Post by nikfubar on Apr 17, 2015 18:43:43 GMT 1
Mmm think you may need to spread the frame, just fitted one to my hybrid & if your running nc29 wheel & sprocket carrier your going to hit the frame with the chain. Ask Trubrit he'll know, he has one on his blue hybrid.
tezrhc
Post by tezrhc on Apr 17, 2015 19:11:03 GMT 1
Thanks for the info nikfubar,I have cut the rear mount bar and removed the centre stand bar,as that one was nackered. cut the new brackets from some 4mm steel.
tezrhc
Post by tezrhc on Apr 17, 2015 19:15:16 GMT 1
Brackets cut and ready to be fitted,with the help of Olive the cat.
tezrhc
Post by tezrhc on Apr 17, 2015 21:11:44 GMT 1
New brackets on.
Post by tsa on Apr 17, 2015 21:32:16 GMT 1
If it were my choice Id NC30 arm it as its easier to make some pipes for than the 29 arm. The 29 arm is offset to the left and sticks out more on the left side than the right. This can look odd from the rear with side by side pipes. The 30 arm can still have side by side pipes as the right one goes behind the footrest hanger.
tezrhc
Post by tezrhc on Apr 17, 2015 21:41:26 GMT 1
Would it be possible to make GP style on the r/h side?
Post by Deleted on Apr 18, 2015 0:50:25 GMT 1
The 30 with GP pipes would look good... though the 29 with side by sides... mmm! Tough choice.
Post by tsa on Apr 18, 2015 9:17:31 GMT 1
This is a set I did with an RC45 arm.
Post by Deleted on Apr 19, 2015 0:42:50 GMT 1
^^^ or maybe them^^^^ It's gonna be a tough call!
tezrhc
Post by tezrhc on Apr 19, 2015 7:51:41 GMT 1
^^^ or maybe them^^^^ It's gonna be a tough call! Can't decide yet,I thought about putting mounts for both linkage's and shocks to be able to swap. The front end is coming the end of the week,I may wait until that goes on before I rush in.
tezrhc
Post by tezrhc on Apr 19, 2015 7:57:10 GMT 1
This is a set I did with an RC45 arm. That looks really good,2 questions-are the pipes different fitment for the YPVS and 4LO engine and also does it matter if your barrels are tuned or not?
Post by tsa on Apr 19, 2015 10:04:02 GMT 1
They would be slightly different fitment depending on how you mount them and how the swing arm linkage goes. These were designed for std cylinders but work well on a fast road tune too.
Post by Deleted on Apr 19, 2015 10:13:04 GMT 1
^^^ or maybe them^^^^ It's gonna be a tough call! Can't decide yet,I thought about putting mounts for both linkage's and shocks to be able to swap. The front end is coming the end of the week,I may wait until that goes on before I rush in. To be honest, I like the look of what you have on there at the moment... Front end wise that is.
tezrhc
Post by tezrhc on Apr 19, 2015 17:54:28 GMT 1
Had to change the linkage on my nc30 so while the wheel was off I tried it on the lc,this wheel is off a 750 and is 17''. I think the single sider is the winner.
