Post by kostas on Dec 28, 2014 21:27:17 GMT 1
I have a problem with the voltage output on my bike, This is a 350ypvs f1, so I start the bike and the voltage I get on the meter it crazy. The meter runs from zero to full scale (20 volts) and continues on this loop constantly.
Replaced the reg/rec with a used one (seller said its from a running bike) but the problem remains. Tested both r/r and the diodes seem to be reversed on both. Is the testing procedure for the r/r written correctly in the Haines book? Searched the old treads and there was someone saying that the book has red and black meter cables the wrong way around...
Tested the coil and the readings are fine. Has anyone had this happen before?
Thanks
Kostas
Post by Roofmonster on Dec 29, 2014 1:18:31 GMT 1
That's a weird problem Kostas - where are you measuring the volts - across the battery? Certainly sounds like a regulator problem but you would be unlucky to get 2 faulty reg/rec.
I don't know about the Haynes book as I don't have one for the f1
Post by kostas on Dec 29, 2014 11:05:11 GMT 1
Yes I'm measuring across the battery terminals. These two r/r are either both good or faulty as both check out exactly the same.
Anyone had this?
Kostas
Post by gibba1008 on Dec 29, 2014 12:29:16 GMT 1
Surely it must be R/R circuit issues as that is what it would read if you bypassed it
Post by cb250g5 on Dec 29, 2014 12:53:46 GMT 1
Try a different meter
Post by 4l04ever on Dec 29, 2014 21:21:29 GMT 1
+1 :-) Also make sure meter is on DC reading not AC.
Post by kostas on Jan 3, 2015 14:52:01 GMT 1
Thanks for the input fellas, Sorted the charging problem today, Turns out my multimeter goes crazy when I get it close to the bike with it running! Even without touching the battery terminals. So I hooked it up to the battery using two long wires and the problem is solved, 14.5 volts output Kostas
Post by cb250g5 on Jan 3, 2015 15:07:01 GMT 1
Post by kostas on Jan 3, 2015 16:55:50 GMT 1
You got this one right mate! Kostas
