Post by iwantalc on Dec 26, 2014 11:39:00 GMT 1
anyone knoww the correct tyre pressures for a rd350lc thanks
Post by Delbert on Dec 26, 2014 12:10:19 GMT 1
Haynes manual states 25psi front - 28psi rear for normal riding .... 28 front & 32 rear for high speed ... Personally I run 26 f & 28 r all the time
Post by iwantalc on Dec 26, 2014 14:02:49 GMT 1
ok thanks
Post by 4l04ever on Dec 26, 2014 17:07:07 GMT 1
Depends on which tyres you are running and for what purpose (track or road). Check the tyre manufacturers websites for their recommended pressures, as they are not all the same.
Bridgestone recommended pressures for BT45s on a 4L0 are 33psi front and 36psi rear
Post by bare on Dec 28, 2014 1:34:31 GMT 1
30/32 psi on Mine as it handles poorly at lower pressures.
Post by Yogi on Dec 28, 2014 11:50:54 GMT 1
You should take into account how much the rider weighs aswell
Post by Delbert on Dec 28, 2014 19:13:22 GMT 1
You should take into account how much the rider weighs aswell looks like bares had a good Christmas ;-)
Post by sp885 on Dec 28, 2014 23:06:32 GMT 1
Depends on which tyres you are running and for what purpose (track or road). Check the tyre manufacturers websites for their recommended pressures, as they are not all the same. Bridgestone recommended pressures for BT45s on a 4L0 are 33psi front and 36psi rear Thanks for this advice, I just put a new set of BT45's on mine , but was running them at 28 front and 32 rear, just got that from the Haynes manual, didn't think to look on the Bridgestone website Steve
Post by stanlc7189 on Dec 29, 2014 2:48:18 GMT 1
I have BT45s and run 30 F 32 R.
Post by 4l04ever on Dec 29, 2014 20:10:55 GMT 1
Some tyres have softer side walls, so need a higher pressure to compensate for this.
