Post by tippo on Dec 21, 2014 14:02:49 GMT 1
Hi, I have bought a new rubber grommet from Norbo for the alternator wiring as it comes through the crankcases. Hole in the grommet looks a little small to get the connectors through so I guess I need to remove the wiring from the connector and then pass through the sleeve. I have tried to get the wires and pins out of the connector but have had no success??
Any advice welcome
Cheers
Post by oldelsieboy on Dec 21, 2014 14:05:20 GMT 1
Hi, I have bought a new rubber grommet from Norbo for the alternator wiring as it comes through the crankcases. Hole in the grommet looks a little small to get the connectors through so I guess I need to remove the wiring from the connector and then pass through the sleeve. I have tried to get the wires and pins out of the connector but have had no success?? Any advice welcome Cheers Purchase a set of these, make the job a bit easier. www.ebay.co.uk/itm/111204883959?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITOEB
Post by tippo on Dec 21, 2014 14:08:35 GMT 1
Cheers for the reply, I guess that the pins just pull out of the block when you apply the tool?
Is it obvious which one I need to use?
Cheers
