Post by seang14 on Nov 30, 2014 23:59:17 GMT 1
I've decided to replace all the Bearings in my LC Gearbox for good measure as renewing the Crank! Where's the best place to buy the Four Bearings required?. One of the Bearings has a Big C' Clip fitted! Does this come off? I've seen picture on Yambits site and they don't show it on the Bearing! Anybody Help??
Cheers Sean G
Post by proam350 on Dec 1, 2014 5:18:13 GMT 1
Yes the clip comes off there is also a caged needle roller bearing the selector drum runs in you may want to check that also I replaced all mine and what a difference it made one very quiet smooth lc engine !!!!
Post by Tobyjugs on Dec 1, 2014 6:08:22 GMT 1
I have bought the bearings off Norbo.
Post by Tone on Dec 1, 2014 7:41:47 GMT 1
If you do decide to go non Genuine, make sure the bearing that goes behind the clutch with the C clip fitted all the way around has the groove for the clip in the centre of the bearing. I got a non Genuine one for my LC2 from a local dealer and only noticed when I went to fit it the groove was offset and not central as on a Genuine one. Ended up sending it back and ordering a Genuine one.
Post by Norbo on Dec 1, 2014 11:18:03 GMT 1
I just do gen yam ones for these bearings.
Post by lb on Dec 1, 2014 13:18:45 GMT 1
Norbs do you sell the gear box seals as well? Aren't they the same as RZ?
Post by tippo on Dec 1, 2014 20:12:21 GMT 1
I have recently been through this on my 350LC resto. Decided to renew all brgs in the g/box and looked everywhere for oem standard alternatives. Had no success, ended up buying the two small needle roller brgs and the clutch brg from Yamaha. The sprocket brg is readily available from any bearing supplier.
Post by seang14 on Dec 1, 2014 21:48:47 GMT 1
Hi Norbo, Do you have all the Bearings for the Gearbox in Stock just Now??? If so I'll drop you an email to get them all from you !!! Cheers Sean G
Post by Norbo on Dec 4, 2014 9:31:06 GMT 1
Yes I have the oil seals and yes I have all the bearings in stock .
