jay
2 stroke or not 2 stroke
Post by jay on Feb 24, 2007 20:36:54 GMT 1
Hi All The engine on my Mk2 is loosing oil from somewhere ?? cant see where though. Also when running it doesn't sound too good (loud knocking/ticking noise). What should i do? get a full engine rebuild??. Looked on stan stephens web site and its £200. What exactly does this include???. I'm planning on totally stripping and re-building it but need the engine to be sweet as a starting point. I am prepared to have a go myself, though no real engine experience. Is this a bad idea?? Any suggestions ?? Cheers
Post by pablo on Feb 24, 2007 20:44:36 GMT 1
;D get a manual and have a go mate...its a rite of passage for LC owners
Post by scott on Feb 24, 2007 21:10:49 GMT 1
if i can do it m8 anyone can.
Post by mellow on Feb 24, 2007 22:13:34 GMT 1
if i can do an f2 engine n e one can do a 125 ;D there really aint much in them
Post by Norbo on Feb 25, 2007 10:34:03 GMT 1
Give it a go mate . The people on here will help you threw in step by step and with a Haynes manual at your side as well i cant see any problems .
jay
Post by jay on Feb 25, 2007 17:47:03 GMT 1
Got a manual and could probably split enging ok, but how do i know what needs repairing/replacing ??
Post by Norbo on Feb 28, 2007 11:17:32 GMT 1
If you have it split i allways just rebuild the crank all new and rebore and piston and rings . That way you know its all new. Its not an expensive job with a 125.
jay
Post by jay on Feb 28, 2007 13:49:46 GMT 1
Degreased all engine and then took it for a spin, turns out that the breather pipe had been spitting engine oil out which had been running all over the casings. What other reason (other than too much oil) would cause this?? Have drained and gonna re-fill to the correct level to see if this sorts the problem.
Post by bryzy100 on Mar 2, 2007 1:24:21 GMT 1
when i rebuilt mine jay it cost 200 in parts if your going to all the trouble of splitting it you just as well do all the bearings and seals new clutch plates and springs and when you put it back to gether and start her up she will sound lovely and your mind is at ease
Post by Dirtbag on Mar 2, 2007 17:23:14 GMT 1
Degreased all engine and then took it for a spin, turns out that the breather pipe had been spitting engine oil out which had been running all over the casings. What other reason (other than too much oil) would cause this?? Have drained and gonna re-fill to the correct level to see if this sorts the problem. It means pressure in your crankcases is built up....forcing the oil to find an escape route , you need to replace your gaskets and oil seals , and by the sound of it your crank is on its way out if its knocking. Basically your motor needs to be overhauled mate
Post by pablo on Mar 3, 2007 18:21:58 GMT 1
just drain it and fill it with the right amount of gearbox oil first mate...some people mistakenly fill up the gearbox with engine oil
Post by Dirtbag on Mar 6, 2007 12:10:11 GMT 1
Have you Pabs ? ;D ;D
Post by mellow on Mar 6, 2007 12:58:52 GMT 1
as if he would ;D
jay
Post by jay on Mar 6, 2007 13:54:05 GMT 1
This sounds thick but i didn't think there would be separate gear box oil ?? Not in the little 125 LC ?? Please advise.
Post by mellow on Mar 6, 2007 15:02:18 GMT 1
2 stroke oil goes in the tank behind the right hand side panel gear oil goes in the black cap/dipstick by the kickstart lever m8
jay
Post by jay on Mar 6, 2007 22:11:09 GMT 1
I thought you meant there was separate gear box oil as well as enging oil, disregarding the 2 stroke stuff. Nice one !!
Post by mellow on Mar 6, 2007 23:02:57 GMT 1
the 2 stroke is the engine oil............the gearbox is the gearbox oil m8
jay
Post by jay on Mar 7, 2007 13:31:19 GMT 1
Think i'm probably getting the terminology right now........ Cheers
Post by pablo on Mar 8, 2007 20:39:04 GMT 1
no,but that TDR did have when i first bought it...bloke couldnt work out why the oil light wouldnt go out,and oil was pissing out of the crankcase breather! ...litre of 2 stroke straight into the gearbox
