Post by wwwRD350LCnet on Nov 25, 2014 22:15:28 GMT 1
Hello,
some years ago, with P51bombay (Dennis) from the old forum, I had worked on an exhaustive list of all parts and colors they should have (Dennis was building a RD350LC with NOS parts !)
Could you (Anoraks and experts like OEB) help me to validate this list ? Then this file could be added in the section "technical info" and will help people doing rebuilds
If English translation is not so clear please correct it !
It's complementary to the "reference pictures" www.skills.plus.com/ref/index.htm
Satin and gloss means parts are painted in black color.
On microfiches sometimes YAMAHA give this info: "YAMAHA black" for gloss black
"Low gloss black" for satin black
ENGINE cylinder head satin cylinders satin clutch cover satin Ignition cover satin radiator satin Water joints satin engine stay rod gloss engine mounting brackets gloss engine stay rod bracket olive green kick lever olive green water hose clamp olive green carburetor and airbox clamp olive green radiator cap olive green clutch and ignition cover screws olive green cylinder head bolts, studs & washers olive green engine screws, whashers and nuts zinc silver
CHASSIS frame gloss Swingarm gloss rear frame stay gloss Lifting handle bar gloss side and central stand gloss wheels satin
FRONT handle bar satin handle switch (left and right) satin Brake Lever satin Clutch lever and braket satin horns and outer brackets satin top yokes satin Main switch housing satin Speedo drive housing satin bottom yoke olive green top fork ball cover (head race cover) zinc silver twin horns bracket olive green headlight bracket gloss front indicator stems olive green indicator fixing bolts, nuts and washers olive green clocks bracket olive green mirror stems olive green front mudguard bracket zinc silver headlight rim Chromated
MIDDLE stand springs zinc silver front & rear footrest bracket olive green front & rear footrest stems olive green pipe exhaust Black coating gear pedal + rod and lever Chromated Seat Latch and Lock satin unlock seat bracket olive green levers on seat latches zinc silver
REAR rear sprocket hub satin rear sprocket gloss chain puller zinc silver rear handle bar Chromated rear reflector bracket olive green
BRAKING master cylinder and splitter joint satin brake caliper satin disk brake satin rear brake pedal olive green drum brake shoe plate satin drum reaction bar gloss rear brake lever (on plate shoe) Chromated rear brake rod zinc silver
MISC wheels, engine and rear arm axles zinc silver others screws, whashers and nuts zinc silver
Thank you
Xavier
Post by shaunthe2nd on Nov 25, 2014 22:38:52 GMT 1
Hey this is great information, once confirmed, thanks.
I'm using SAS 27 gloss black from Yambits. Can anyone recommend a good rattle can for touching up the satin black bits?
Thanks in advance. Hope its doesn't distract from Xavier's request.
stevep
Post by stevep on Nov 25, 2014 23:39:20 GMT 1
Halfords own satin black
Post by mcguyver on Nov 26, 2014 1:44:34 GMT 1
Brilliant. Thanks for posting
Post by bofski25 on Dec 16, 2014 9:03:12 GMT 1
Hey this is great information, once confirmed, thanks. I'm using SAS 27 gloss black from Yambits. Can anyone recommend a good rattle can for touching up the satin black bits? Thanks in advance. Hope its doesn't distract from Xavier's request. im using b&q barbeque paint its also brilliant for painting the exhausts
Post by oldelsieboy on Feb 20, 2015 13:06:24 GMT 1
My only observations are on the finish of the footrest parts. AFAIK the front footrest bracket is satin black & the rear is olive. The front footrest stems are olive but the rears are chrome.
OEB
Post by wwwRD350LCnet on Feb 22, 2015 18:32:49 GMT 1
Thank you OEB
On the next update of my website I will add this list...
Xavier
Post by kusanagi47 on Apr 9, 2015 20:08:47 GMT 1
I've had a lot of problems with Hanford paint and now avoid it like the plague. Colour fastness is dubious, I did my tank with it and after a few months it faded and cracked off. Other areas it turned into a kind of rough,bubble foam but as hard as glass. Had to burn it off! i now only use Multona paint. It's high quality,German made and excellent.
Post by Norbo on Apr 9, 2015 21:26:53 GMT 1
Excelent I think ill add this to the info page if you don't mined .
Post by Jona on Feb 12, 2023 22:06:13 GMT 1
Hello,
Thank you
Xavier
Hi All I have done a search but wondered if there was a similar list for an LC2 or is it the same ? Thanks in advance
