Post by iwantalc on Nov 16, 2014 9:50:46 GMT 1
bike in bits advertised as 350 says not matching 4l0 unless my eyes are worse than i thought pictures show both 4l1
Post by iwantalc on Nov 16, 2014 9:57:25 GMT 1
listing just been changed to 4L1
Post by Yogi on Nov 16, 2014 10:06:37 GMT 1
Just noticed that,so its a non matching 250 then,very vague an no pics either? But says he's already got a 350 so knows the difference?
Post by iwantalc on Nov 16, 2014 10:46:24 GMT 1
it had pictures on the first listing ...white with red stripe and red seat
Post by oldelsieboy on Nov 24, 2014 16:09:53 GMT 1
Is it just me or do these bore look a tad small for a 350 Not the best comparison photo but best I could find with out stripping my motor LOL OEB
Post by Yogi on Nov 24, 2014 18:48:50 GMT 1
He has changed to 4l1 not matching,so it is a 250
Post by oldelsieboy on Nov 24, 2014 19:13:16 GMT 1
Post by Yogi on Nov 24, 2014 19:16:58 GMT 1
It's still listed as a 350 to try and catch someone but he's put 4l1 in the description to cover his arse?
Post by markhoopy on Nov 24, 2014 21:50:54 GMT 1
I sent a message to the seller: The 4L1 is a 250 as you probably already know, but you have put RD350LC in your listing title .. the photo showing the barrels/pistons are clearly of a 250LC (54mm bore), so you are selling a 250LC with non-matching engine and frame numbers and not a 350 as stated? If you are unsure then could you measure the bore diameter before I place a bid? Thanks I'll post his reply if I get one ..
Post by oldelsieboy on Nov 24, 2014 21:53:46 GMT 1
I asked him to confirm the motor was 350 & he stated he had been informed it was 250 but could not edit the listing OEB
Post by markhoopy on Nov 24, 2014 22:01:28 GMT 1
That's true - once bids are made the title can't be changed. Doesn't stop him adding to the item description though!
Post by steve h on Nov 24, 2014 22:01:54 GMT 1
Looks like the frame is cracked on the headstock above and to the right of the numbering, and a dent to the left of the crack. At £1k plus............
