ypvs
Oct 30, 2014 19:26:37 GMT 1
Post by iwantalc on Oct 30, 2014 19:26:37 GMT 1
what model ypvs engine numbers start 1wt also is the rev counter cable or electric thanks
ypvs
Oct 30, 2014 19:35:32 GMT 1
via mobile
Post by midlifecrisisrd on Oct 30, 2014 19:35:32 GMT 1
1wt was later f2 ypvs
It has an electronic tacho so the drive gear is not fitted however if you are splitting the cases you can fit the mechanical drive.
Only the 4ce engine cannot be retro fitted without machining the cases
ypvs
Oct 30, 2014 19:46:32 GMT 1
Post by iwantalc on Oct 30, 2014 19:46:32 GMT 1
the bikes a31k but been fitted with this engine so will the 31k rev counter be electronic thanks
ypvs
Oct 30, 2014 21:37:58 GMT 1
Post by Yogi on Oct 30, 2014 21:37:58 GMT 1
If its got the electronic rev counter its only 1 wire into the loom to get it to work, could also be cable if someone's put the drive in the gearbox but as Steve said they would have had to split the cases to install the drive gears
ypvs
Oct 30, 2014 21:39:03 GMT 1
via mobile
Post by midlifecrisisrd on Oct 30, 2014 21:39:03 GMT 1
the bikes a31k but been fitted with this engine so will the 31k rev counter be electronic thanks 31k lc2 has mechanical tachograph (kidney clocks) 31k n1/f1 had elect tacho Steve
ypvs
Oct 30, 2014 21:52:54 GMT 1
Post by JonW on Oct 30, 2014 21:52:54 GMT 1
Anything 85-on has an electric tacho. If the clocks are pre 85 then they need a cable.
ypvs
Oct 30, 2014 23:03:42 GMT 1
Post by iwantalc on Oct 30, 2014 23:03:42 GMT 1
ok thanks everyone for all the info ...
