Post by rich on Oct 29, 2014 14:27:20 GMT 1
Any tips for cleaning old threebond off gasket faces?
mkane
Post by mkane on Oct 29, 2014 14:42:20 GMT 1
Wire wheel
Post by yamagama on Oct 29, 2014 15:00:42 GMT 1
I use thinners and a stanley blade.
Post by looey on Oct 29, 2014 15:11:41 GMT 1
I'm fairly sure it comes off very easy with brake cleaner, once you've bladed the worst off.
Post by midlifecrisisrd on Oct 29, 2014 15:46:09 GMT 1
Not sure of the number but the threebond I use comes off with cellulose thinners
Post by dusty350 on Oct 29, 2014 15:50:38 GMT 1
Thinners for me too Dusty
Post by rich on Oct 29, 2014 18:21:44 GMT 1
Cheers guys
Post by Deleted on Oct 31, 2014 5:08:18 GMT 1
gasket remover in a can, i wouldn't use a wire wheel or buff pad it'll destroy the surface
my mech used a razor blade followed by a fine stone
mkane
Post by mkane on Oct 31, 2014 14:14:57 GMT 1
Been using wire wheels since I can't remember. Your more likely to mare the surface with a blade.
Post by Tobyjugs on Oct 31, 2014 18:40:35 GMT 1
I used degreaser and and green scotch bright.
mkane
Post by mkane on Nov 1, 2014 14:25:12 GMT 1
scotch brite pads a goo idea also
stevep
Post by stevep on Nov 1, 2014 23:18:06 GMT 1
Wheel and or a blade is a bit brutal on mating gasket surfaces , use cellulose thinners and scotchbright
Post by sbscnor on Nov 2, 2014 11:26:02 GMT 1
Did mine last week ThreeBond 1104, I used Motul brake cleaner sprayed onto a cloth all removed in 10 mins with no damage to the faces.
Post by bare on Nov 7, 2014 5:00:08 GMT 1
Laquer thinners ?? OR use 1204 Threebond 'next time'. It peels off, in one piece, if passably careful. Costs wayy more than the Grey Goop though. Pick yer poison :-0
