Post by JonW on Oct 29, 2014 0:02:03 GMT 1
Ive a set of 250LC cigars and I want to use them on my 350 build. I remember people saying there was a restricter plate in the body and that should be taken out as otherwise they are the same pipe. Can anyone confirm and offer advice on how to do it?
Post by skaterboy on Oct 29, 2014 0:22:59 GMT 1
I maybe wrong but seem to remember the 250 pipes have four holes in the restriction plate and the 350 had 6 holes in the restriction plate.
Post by JonW on Oct 29, 2014 2:56:46 GMT 1
Post by JonW on Oct 29, 2014 5:43:19 GMT 1
I maybe wrong but seem to remember the 250 pipes have four holes in the restriction plate and the 350 had 6 holes in the restriction plate. Interesting, so open them up (cut em in half I guess?) and drill 2 more holes in said plate, or just remove it? Also, where is the plate located? Dont want to cut the wrong part :/
Post by steeley on Oct 29, 2014 6:22:50 GMT 1
jonw hi,i can help you out there I have a pair cut open that I am repairing at the moment .I will get some video/pictures of the inside.
Post by JonW on Oct 29, 2014 6:51:57 GMT 1
Thats brilliant mate, thanks so much!
Post by oldelsieboy on Oct 29, 2014 9:17:16 GMT 1
250 Pipe350 PipePosition of PlateThanks to Kevin (Redbimota) for the photos. OEB
Post by JonW on Oct 29, 2014 11:53:33 GMT 1
Wow, cool. Thanks for sharing Nigel.
So, whats the opinion, should I remove that mesh as well as drill more holes?
Post by oldelsieboy on Oct 29, 2014 12:44:00 GMT 1
Wow, cool. Thanks for sharing Nigel. So, whats the opinion, should I remove that mesh as well as drill more holes? With 250 pipes fitted to a 350, I doubt if you will notice any difference in normal road riding & probably not much on a dyno either. OEB
Post by steeley on Oct 29, 2014 17:23:54 GMT 1
had a look at the ones I have they are defo 350 pipes they have four holes in the plate but they are larger diameter .will see if I can get the pics up later.the plate is about 7.5 inches from the bottom of the first cone measuring to the back.
Post by arrow on Oct 29, 2014 17:45:59 GMT 1
Wow, cool. Thanks for sharing Nigel. So, whats the opinion, should I remove that mesh as well as drill more holes? With 250 pipes fitted to a 350, I doubt if you will notice any difference in normal road riding & probably not much on a dyno either. OEB I had 250 pipes on my 350 when I first got it. Low and mid range are improved just a tad down on the top end power. No other issues.
Post by steeley on Oct 29, 2014 18:12:56 GMT 1
Post by steeley on Oct 29, 2014 18:49:35 GMT 1
bugger, that didn't work.
Post by redbimota on Oct 29, 2014 21:34:26 GMT 1
had a look at the ones I have they are defo 350 pipes they have four holes in the plate but they are larger diameter .will see if I can get the pics up later.the plate is about 7.5 inches from the bottom of the first cone measuring to the back. Why do you think you have 350 exhaust if they have only four hole, both 250 & 350 exhaust have 4L0 part number stamped on them, check the rear hanging bracket on the back it should have 0 stamped on the back if there 350. Kev
Post by JonW on Oct 29, 2014 22:15:18 GMT 1
Thanks so much guys, so in fact people would say dont bother to cut them up, just run em? Its a road bike and I ride in traffic quite a bit so low down is more useful than revvy if im honest, but who doesnt like to enjoy a bit of revs when they can... LOL!
Post by steeley on Oct 30, 2014 6:20:46 GMT 1
cheers for that kev,i will have a look later .I have had these pipes for about 20 years I was given them by a mate of mine.if they are 250 its time for the drill then lol.
Post by JonW on Oct 30, 2014 22:29:58 GMT 1
Ray, I reckon youve got 250 pipes from whats been said and your pics/vid, so time to drill I guess.
Are you repairing the dents in yours and removing the mesh?
