begbie
Post by begbie on Oct 9, 2014 18:05:12 GMT 1
Had my rebuilt F2 Dyno'ed on a Dynapro a few months ago, It has the following spec. Rebuilt crank .5 rebore and Matika pistons Stock porting stock carbs unknown fiber reeds stock head but used one leaf of an Athena head gsk TSA mid range pipes stock Ign and pv control Kenny said pipes should peak around 10,400, so think with a programable ign and a little more advance at the top end could free up a few more horses. red lines F2 blue lines stock RGV 21 green lines piped RGV 21 anyone have a graphof a ypvs in a similar state of tune they want to share ?
Post by midlifecrisisrd on Oct 9, 2014 20:03:32 GMT 1
His race pipes will peak at 10500. Midrange will be around 8
Looks like you have his road pipes which will peak before 10
My tsa pipes peak at 9400
Your making good power for standard porting
begbie
Post by begbie on Oct 9, 2014 20:14:03 GMT 1
Oh Yeah, just checked an email from TSA "Road ones peak at 9600-10000rpm depending on setup and the race ones peak at 10400-11000rpm again depending on setup."
Post by mikee on Oct 9, 2014 21:50:04 GMT 1
The 31k in my mito made 53 @ 9600 ish on mick abbeys dyno Stock barrells , but for boysen ports Stock yam head gasket and head Power valves locked open TDR reeds and cages Martin Johnstone pipes F2 ignition , lightened flywheel 53 mm s&b filters on 20mm spacers
I'll dig out the printout and post it up
Mike
Post by botty on Oct 9, 2014 22:28:10 GMT 1
31k Standard porting Kenny Mid range pipes Zeeltronic PWK's Rammair filters
