Post by marddy on Oct 6, 2014 19:03:55 GMT 1
My Jap YPVS RZR250 has 51L-50 CDI that has 8 wires - Orange, Red/White, Black, Black/White, White/Red, Green, White/Green and Brown. Will 31K wiring loom fit? Or, which YPVS model wiring loom fits? Need advice.
Post by rich on Oct 6, 2014 22:40:00 GMT 1
No, unfortunately the different 'generations' of YPVS (LC2, F1/N1, F2/N2 and 350R) all have different looms which are too different to interchange. As your bike is an import, the nearest suggestion would be a loom from the equivalent UK model which would be an F1 or N1 as they run an 8 wire CDI.
Post by kosaprasa on Oct 6, 2014 22:47:38 GMT 1
hi
which wire loom 31K? on your CDI Will fit 51L wire loom allso fit on that wire loom 52Y-50 CDI, if you do little modification on wire loom 29L-50 Will fir your CDI as well and allso rev meter Will work
cheers
Post by marddy on Oct 8, 2014 19:55:18 GMT 1
Thanks Kosa. You are suggesting 31K loom from UK model YPVS?
Any more inputs please as I want to overcome my crappy wiring and therefore, the problems I face.
Post by JonW on Oct 10, 2014 0:38:20 GMT 1
Hmm... Is this bike a fully faired F1 RZR or the N model? If its an F and from 84/85 then it needs a 57V loom, sadly hens teeth to find. N models are different though and you may well find something that works, the 31k is different as it has no tacho feed out of the box as has been said.
Post by midlifecrisisrd on Oct 10, 2014 12:05:19 GMT 1
Had a 250 stator once and looked identical to F1 and N1
As Jon says it depends whether it is naked or faired and whether it has mechanical or electrical tacho feed.
31k lc2 loom can run an electronic ypvs tacho. Just connect the grey trigger wire to the black/yellow from the cdi that feeds to the pv controller.
Post by marddy on Oct 10, 2014 19:43:56 GMT 1
Mine is a naked version with an electronic tacho. So, will a 31K LC2 loom fit? Where can I get this loom?
Post by midlifecrisisrd on Oct 10, 2014 20:11:44 GMT 1
No you will need an N1 loom
Post by JonW on Oct 10, 2014 23:31:45 GMT 1
Steve, er... didnt you just says 31K with wiring mod above will run an N1?
Post by midlifecrisisrd on Oct 11, 2014 0:00:09 GMT 1
Steve, er... didnt you just says 31K with wiring mod above will run an N1? Yes but would need stator, flywheel, switchgear, cdi and clock wiring changes. N1 looms on ebay every so often Steve
Post by kosaprasa on Oct 11, 2014 8:02:54 GMT 1
i can help you, but i must know what exetlly you have on bike, pictures wellcome, i have few wirelooms on stock in good condition
kopite30
http://www.motomovers.uk
Post by kopite30 on Oct 12, 2014 14:28:23 GMT 1
Hi Bud I'm after wiring loom for ypvs F2 can you help kosaprasa
Cheers Mike
Post by midlifecrisisrd on Oct 14, 2014 12:31:17 GMT 1
Mine is a naked version with an electronic tacho. So, will a 31K LC2 loom fit? Where can I get this loom? N1 loom on ebay in perfect condition Steve
Post by marddy on Oct 14, 2014 19:42:01 GMT 1
Hi Steve,
Yes, there is a wiring loom on the eBay. Item number is 351195359591. Is this loom a direct fit or will need to be modified/altered.
Post by midlifecrisisrd on Oct 14, 2014 20:06:36 GMT 1
Hi Steve, Yes, there is a wiring loom on the eBay. Item number is 351195359591. Is this loom a direct fit or will need to be modified/altered. On my phone but yes looks like you have found it. The seller is books123eddie and it has an 84 quid buy it now. It is the only UK naked model. It uses the elec tacho and an 8 wire cdi so is your best bet. You can always sell it on if no good, rare so will sell no problem. Hurry as one in that condition won't be there long Steve
Post by marddy on Oct 15, 2014 11:04:01 GMT 1
Thanks Steve. It looks like I have lost it to another buyer. Sad, very sad indeed ... wanted it as my present loom is not in a good shape.
Where else can I get another one?
