dave37
Post by dave37 on Oct 5, 2014 20:24:49 GMT 1
Hi guys/girls, Ive been getting my old f2 ypvs running again after i let it rot in back yard for 10 years(i know im a t**t) ive got it running ,stripped and fixed carbs ,brakes fuse box er everything really but still have some way too go!! bike feels lumpy at low revs and then smooths out and sounds great and idles fine .the ypvs valve is not quite right you can here it when you swich it on but i think its stopping at the open position. is the slot on the valve pully ment to line up with the hole in the back plate when closed or open? . Also are the carb float bowls the same as each other and be fitted to either carb?. or is one made for left and one made for the right?. I sooo want this bike up and running because no modern bike get anywhere near it for me. many thanks.
Post by kostas on Oct 5, 2014 21:55:40 GMT 1
PV slot aligns with hole at full open. Carb bowls are different. choke side bowl has a small hole drilled on a passage at the bottom of bowl.
Shame having the bike rot for 10 years.
Kostas
dave37
Post by dave37 on Oct 6, 2014 9:14:51 GMT 1
many thanks for the help , dose that mean at idle the slot in the powervalve pully dose not line up with the hole in the back of the housing?
phil38
Post by phil38 on Oct 6, 2014 13:32:36 GMT 1
many thanks for the help , dose that mean at idle the slot in the powervalve pully dose not line up with the hole in the back of the housing? That's right. It stops open but moves closed once the engine starts. You can check its operation at standstill just by revving it to ~7k.
dave37
Post by dave37 on Oct 6, 2014 14:23:28 GMT 1
got it thanks , thats where i was getting stuck! .
