alexm
Post by alexm on Oct 2, 2014 23:10:17 GMT 1
I have just picked up my latest toy from Classic Super Bikes in Fleet - a very original RD500LC. It has done 31,000 miles and 5 owners from new. Whilst riding back on the M25 I noticed on the overrun (about 70mph) a slight vibration occurring on the footrests. As soon as the engine is under load it stops.
Any ideas?
Also during stationary tick over there is a grumbling noise was coming from the engine, I have been told this is quite normal and they all sound like "a bag of nails". Is this correct?
It seems to accelerate quite well with no excessive smoke from pipe.
Am I getting paranoid???
Thanks
Post by jackjabba on Oct 3, 2014 8:49:12 GMT 1
Mine doesn't sound like a bag of nails and its still waiting for me to get the engine rebuilt. Find someone in your area with one and go take a listen to theirs.
Take a look on the RD/RZ Forum and ask if theirs anyone near you.
If your round the bottom of the M25 go see Stan Stephens and get him to take a listen.
Post by LC_BOTT on Oct 3, 2014 15:50:39 GMT 1
Isn't the overrun vibration normal, and due to the timing of the cranks?, you can use the front or rear crank for balance shaft timing, sorry can't remember what standard is, but it can alleviate this trait, saying that, doubt you should feel more than a tingle. Is it twice as bad as a 350? The last one I heard at tickover sounded ok to me, what do you mean 'bag of nails' I'd be worried if any of my bikes sounded like that
Post by kostas on Oct 3, 2014 15:59:54 GMT 1
I have no experience with the 500 but from the little I know on th 350 your problem sounds expensive
Post by ellasae on Oct 3, 2014 16:48:21 GMT 1
I'm no expert on the 500 having only owned one for a couple of months years ago but i'd be taking it back to the dealers
There's no way it should sound "like a bag of nails" you may well have paid top dollar for a machine that needs a fortune spending on it by the sound of it.
Post by 500anorak on Oct 3, 2014 16:55:07 GMT 1
It`s a common thing on a 500,Yamaha used to change the balance shaft drive from the front crank to the rear if a customer complained back in the day. Yamaha said that all 1985 model bikes had the drive from the rear crank but this was not true.The only bikes to leave the factory set up this way were a very small batch of RZ500S bikes built as a 1986 model which only went to Canada. Most people who carry out the mod report no difference.Having the carbs balanced can make a big difference.(see link) www.rzrd500.com/500phpBB3/viewtopic.php?f=3&t=7751
Post by Bazille on Oct 4, 2014 17:12:02 GMT 1
Hi as above, make sure all gear timings are correct, I rebuilt mine a couple years ago and took photos of gears before rebuilding to make sure! I dont get any bad vibrations through pegs on my bike and it certainly doesnt sound like a bag of nails on tickover However you must be certain that the carbs are all synchronised and set up correctly else the cylinders can "fight" each other and cause tickover noises but once set up should sound sweet, dont take their word for it that they all sound like a bag of nails cos they dont!
cheers
Post by blakeseven on Oct 4, 2014 20:14:20 GMT 1
Grumbling noise bottom end ? I think a trip back to the dealer would be in order .Mine does nt sound like a bag of spanners at tick over and I cant recall any unexplained vibes on the over run ,but to be honest my slowing down is usually in a mad panic as the corner arrives sooner than I thought
Post by strokeofgenius on Oct 4, 2014 21:48:47 GMT 1
Mine is quite noisy at tickover.if the noise is from rhs then its the clutch and is normal.It shouldnt be dry clutch noisy but there is a definite low rattle.It has been mentioned many times on the 500 forum as has the roughness on the over run which mine does with aplomb.I remember worrying about these 2 issues ten years ago when I first bought bike.Mine has been fully rebuilt with new cranks pistons etc and sounds very same as when I first got it.About 6 years ago the roughness on over run seemed to get worse but turned out to be ht caps breaking down and exasperating existing condition.Still for your own peace of mind it would be nice to a hear another 500 running beside your own.
Post by jackjabba on Oct 5, 2014 10:17:55 GMT 1
If I was you I would go and get a second opinion from someone who knows what they are on about. I bet you paid a considerable amount of money if you got it from a dealer, and they would tell you anything if they thought they were going to have to pay for an engine rebuild.
keep us informed of how it goes.
Post by yamfan on Oct 5, 2014 11:05:00 GMT 1
Grumbling noise could be big ends, get it back to the dealer mate before it possibly costs you money.
alexm
Post by alexm on Oct 5, 2014 22:29:17 GMT 1
Thanks for all your comments - will let you know
alexm
Post by alexm on Oct 10, 2014 13:34:26 GMT 1
I would like to thank everyone for their comments, many of which were very informative and most useful.
I spent a morning off work removing the fairing and having a good inspection.
I tuned the carbs with an air flow meter and found them to be out quite considerably.
Then I done a compression check which revealed 110 PSI for two of the cylinders and 108 PSI for the other two.
I took the bike to Bob Farnham Tuning based in Sevenoaks Kent, who was most informative and helpful. His initial impression was, that for a 30 year old bike in original condition, everything seemed in good order. He was happy with the engine note and the various gear noises (which was a relief).
The bike has had 5 previous owners but unfortunately the history folder is a little light with no documentation of any engine rebuild etc etc. I will make contact with the previous owners to see if any more information can be uncovered on the bike.
However, as the bike is a “keeper” I will probably commission Bob to undertake a full engine rebuild for me over the winter months which will give me peace of mind.
Post by copper99 on Oct 10, 2014 18:43:38 GMT 1
I do love a happy ending....Nice one Alex.
paulr
Post by paulr on Oct 11, 2014 16:45:48 GMT 1
It takes a while to learn what's normal and what's breaking up on any bike... great that you are comfortable now.
