Post by hardhatharry on Sept 28, 2014 17:56:41 GMT 1
Done the distingushed gentlemens ride today and traveling at 10mph caused the water to boil up and 120C on the dash.
Bike behaves its self when travelling normally
Its a hybrid with a PV engine, LC rad and RGV front
Anyone fitted fans to the rad and how did you do it?
Cheers
Post by jessy03 on Sept 28, 2014 18:22:56 GMT 1
You will struggle to find a fan small enough, I have a similar set up, I went for an oversize rad with the std grill and works great. Jess
Post by hardhatharry on Sept 28, 2014 19:35:46 GMT 1
where did you get your oversized rad from? My mate got one from eBay but he cannot fit his original rad cowl as it hits the mudguard when ridden.
Post by jessy03 on Sept 28, 2014 19:46:05 GMT 1
Norbo and mad biker sell them, I got mine off eBay and needed a bit of work to get it to fit Jess
Post by rigga on Sept 28, 2014 20:15:16 GMT 1
I use a small brushless computer fan on my supermoto, 12v compact works well.
Post by bare on Sept 29, 2014 4:07:52 GMT 1
More Rad / Fan etc can't hurt. But IMO you have a fueling/ignition problem that needs sorting... before any Rad/fan issues.
Post by hardhatharry on Sept 29, 2014 20:26:05 GMT 1
Im running lean on the needle that I know, I need a richer needle but need to figure out what needle is in the 28mm carbs norbo sells
