Post by messer on Sept 26, 2014 15:11:25 GMT 1
Not really sure the best way to describe it but after rebuild my ypvs engine seems quite lethargic and heavy to rev and not as responsive as it should be. Any ideas? I'll try and do a video and upload over the weekend. .
Post by jackjabba on Sept 26, 2014 16:15:04 GMT 1
Checked the power valves are linked and working?
Post by messer on Sept 26, 2014 18:03:33 GMT 1
Yeh they are working fine. This is just revving on the stand not driving it
Post by kostas on Sept 26, 2014 19:14:50 GMT 1
So when driving it is ok? Or have not tested yet?
Kostas
Post by messer on Sept 26, 2014 19:59:29 GMT 1
Not tested yet only fired it up on the stand
phil38
Post by phil38 on Sept 26, 2014 20:56:11 GMT 1
May feel a bit tight if it' needs running in. I'd take it easy for a bit and run it in properly before revving the tits of it
Post by kostas on Sept 26, 2014 20:58:10 GMT 1
Why don't you check that all bolts are tight... Exhausts, intakes, etc.. If not that then it should be incorrect mixture setting, so we are back to carb setting
Post by messer on Sept 26, 2014 21:53:30 GMT 1
Yeh I've done that and all ok. I've checked the air screws are fine which they are. I've never rebuilt an engine that felt like this before so not convicted that riding it will fix it. I wondered whether it was the build oil as I did use a fair bit and havent really had a lot of heat in it yet to burn it all off bit did run it for a couple of minutes earlier today. Both cylinders are firing now as the coil connections were furred up. I'm going to re clean the cdi connection on the loom and make sure that's clean along with the other loom joints and take it from there.
Post by messer on Sept 29, 2014 14:25:43 GMT 1
fixed. the throttle slides were mixed up
