jackr1
"Racing makes heroin addiction look like a vague desire for something salty..."
Post by jackr1 on Sept 25, 2014 9:11:09 GMT 1
Everyday is a school day so, what the difference between the 250 & 350 rear wheel ? Is it an easy spot ?
Post by steven on Sept 25, 2014 9:44:31 GMT 1
Hi Jack, Yes, Its easy to spot once you see the difference. The 350 has a seperate cush drive for the rear sprocket carrier, different spacers, and the hub is wider to look at. There is a third bearing for the sprocket carrier too. If you have a look at this website and download and look at the parts lists for the 250/350 you will see the difference no probs. regards, steven. www.rd350lc.net/index.htm
jackr1
Post by jackr1 on Sept 25, 2014 10:14:55 GMT 1
Hi Jack, Yes, Its easy to spot once you see the difference. The 350 has a seperate cush drive for the rear sprocket carrier, different spacers, and the hub is wider to look at. There is a third bearing for the sprocket carrier too. If you have a look at this website and download and look at the parts lists for the 250/350 you will see the difference no probs. regards, steven. www.rd350lc.net/index.htmThanks, the days of my 350 are a distant blur so I have to try to jog the old grey matter
