Post by fastas1 on Sept 23, 2014 20:18:03 GMT 1
Anyone using a cool head on a tuned valve lump? Any good? What size domes are best?
Cheers, Mike
Post by botty on Sept 23, 2014 20:37:48 GMT 1
Anyone using a cool head on a tuned valve lump? Any good? What size domes are best? Cheers, Mike Waiting with interest M8. I'm looking to do the same conversion.
Post by frostie on Sept 23, 2014 20:45:25 GMT 1
thinking about one swell
Post by Bozzy on Sept 24, 2014 1:24:56 GMT 1
thinking about putting one on standard motor?
Post by powellm976 on Oct 5, 2014 13:22:11 GMT 1
I've got a cool head from a banshee to go on an ypvs lump, 18cc domes will see how it hoes if I can figure out the tough bit. The coolant passages are a different shape on the power valve cylinders to clear the power vale, I'm thinking to fill the passage maybe 10mm thick with devcon or jbweld and the re drill to suit the head oring, any thoughts?
Post by slinger on Oct 5, 2014 13:54:28 GMT 1
I've got a cool head from a banshee to go on an ypvs lump, 18cc domes will see how it hoes if I can figure out the tough bit. The coolant passages are a different shape on the power valve cylinders to clear the power vale, I'm thinking to fill the passage maybe 10mm thick with devcon or jbweld and the re drill to suit the head oring, any thoughts? Banshee heads have a different stud pattern than the YPVS so it won't fit.
Post by yazza54 on Oct 5, 2014 14:29:49 GMT 1
Post by powellm976 on Oct 5, 2014 14:37:28 GMT 1
I've got a cool head from a banshee to go on an ypvs lump, 18cc domes will see how it hoes if I can figure out the tough bit. The coolant passages are a different shape on the power valve cylinders to clear the power vale, I'm thinking to fill the passage maybe 10mm thick with devcon or jbweld and the re drill to suit the head oring, any thoughts? Banshee heads have a different stud pattern than the YPVS so it won't fit. You sure about that, seems to go in the studs just fine, it's the water galleries that don't line up
Post by slinger on Oct 5, 2014 22:02:39 GMT 1
Banshee heads have a different stud pattern than the YPVS so it won't fit.M You sure about that, seems to go in the studs just fine, it's the water galleries that don't line up Ok I could have worded it differently, but it don,t change the out come............they don't fit simple. Yeah the stud go into the holes but all the important bits don't line up. A lot of work for nothing to make them fit.
Post by Norbo on Oct 6, 2014 8:36:19 GMT 1
Post by fastas1 on Oct 6, 2014 9:29:19 GMT 1
Thanks all!
Mike
kjellg
Post by kjellg on Oct 6, 2014 20:50:56 GMT 1
Will the first one "Cool Head Kit All so available in Anodised Black £245" fit straight on with thermostat etc ? I have 65.25 mm bore and std crank, will the standard domes be suitable ?
