Post by Delbert on Sept 23, 2014 20:11:01 GMT 1
Been trying to get the self cancelling indicators to work ever since I've had Elsie on the road , tried gen yam flasher unit & self cancel relay etc etc to no avail , low and behold on the way home from work by some miracle they start working all by themselves !! Well a fix is a fix
Post by reggieperrin on Sept 26, 2014 9:19:40 GMT 1
I spent hours and hours getting the SCI on my N1 resto to work. The reed switches in the speedo are very fragile and easily damaged, plus, if you have to try to put a new reed switch in circuit the wiring is almost always corroded... Did you hit any big bumps on the way home...? reckon you've suddenly knocked the reed switch back into position luckily...!!
