Post by messer on Sept 22, 2014 19:09:34 GMT 1
Just wondered how to turn the fuel tap off? The vacuum doesn't seem to make any difference and have just rebuilt it..
Post by andrew on Sept 22, 2014 19:15:22 GMT 1
When I rebuilt mine, the tap always "dripped" but then went into full flow when the vacuum is applied, always wondered whether this was a problem or not? bike seems fine though so left it like that
Post by frostie on Sept 23, 2014 22:20:17 GMT 1
there isn't an off position , just on, prime and reserve . the fuel shouldn't flow in the on position until you fire the bike up.
Post by messer on Sept 23, 2014 23:07:37 GMT 1
Hmm. Makes no difference where it's positioned it just pisses fuel out and have just fitted rebuild kit too.
Post by Tone on Sept 24, 2014 7:00:47 GMT 1
Did you refit the spring between the diaphragm and the removable plate of the tap?
Post by speedar on Sept 24, 2014 8:27:11 GMT 1
Had same problem even after fitting rebuild kit. I pulled the spring slightly assuming it had compressed over time. Problem solved.
Post by messer on Sept 24, 2014 9:31:33 GMT 1
Yeh fitted the spring ill stretch it and see if that helps. If not ill fit an inline tap
Post by messer on Sept 29, 2014 19:07:26 GMT 1
I'm getting full flow on res and pri but partial flow on on.. That's with no vacuum applied. .
Post by messer on Sept 30, 2014 11:01:47 GMT 1
Fixed there was some debris that got stuck on the o ring seat inside. Cleaned off and taps working a treat
