Post by stusco on Sept 19, 2014 17:40:04 GMT 1
Anyone know why the clutch adjuster in the middle of the clutch has cracked my freshly vapour blasted casing (ypvs) I'm really peed off can I get this welded it's prity thin?
Post by stusco on Sept 19, 2014 17:46:19 GMT 1
Sorry for the word prity I'm p###ed off the casing has 4lo on it are the ypvs and lc different ?
Post by oldelsieboy on Sept 19, 2014 19:16:41 GMT 1
Anyone know why the clutch adjuster in the middle of the clutch has cracked my freshly vapour blasted casing (ypvs) On the inside of the 4L0 cover there is a protrusion in the centre of the domed clutch cover area, it is not there on the YPVS cover, maybe this is your problem. OEB
Post by muttsnuts on Sept 19, 2014 20:11:53 GMT 1
the casings are different and an LC casing on the YPVS engine will do this
Post by stusco on Sept 19, 2014 20:24:55 GMT 1
Thanks I worked it out when I calmed down nothing like money down the drain to cheer you up on a Friday night!
Post by stusco on Sept 20, 2014 9:41:13 GMT 1
Canyou remove the protrusion and fit it or will it stop the clutch operating properly or do I need a ypvs casing
Post by oldelsieboy on Sept 20, 2014 9:45:37 GMT 1
Canyou remove the protrusion and fit it or will it stop the clutch operating properly or do I need a ypvs casing Yes it can be removed. OEB
Post by rich on Sept 20, 2014 9:50:23 GMT 1
Yes just drill it off flush with a large bit or slice it off with a Dremel cutting disc.
Post by arrow on Sept 20, 2014 10:16:17 GMT 1
I have a ypvs r/h casing. Its yours for the cost of the post only, if you want it. It does have some light scuff marks.
Post by oldelsieboy on Sept 20, 2014 10:18:52 GMT 1
Dont forget the oil pump covers also differ between 4L0 & YPVS.
OEB
Post by stusco on Sept 20, 2014 11:18:30 GMT 1
Dont forget the oil pump covers also differ between 4L0 & YPVS. OEB That's a good shout I was just about to order a carbon fibre cover thanks for the info
Post by steeley on Sept 21, 2014 8:29:38 GMT 1
your cracked casing is now a candidate for a clear clutch window.just a thought.
Post by carioca656 on Sept 21, 2014 11:57:12 GMT 1
does anybody sell the clear round windows?
adie
Post by stusco on Sept 21, 2014 16:19:10 GMT 1
That will be the last resort not what I had planned,I had two good casing aqua blasted then polished them ,they were mint but if I can get them welded I will be back on track
Post by steeley on Sept 21, 2014 19:26:39 GMT 1
if there is no fairing on the bike/even if there was a mod like this makes clutch adjustment easy.
Post by stusco on Oct 2, 2014 13:40:52 GMT 1
{\rtf1\ansi\ansicpg1252 {\fonttbl\f0\fnil\fcharset0 .HelveticaNeueInterface-Regular;} {\colortbl;\red255\green255\blue255;\red153\green153\blue153;\red255\green255\blue255;} \deftab720 \pard\pardeftab720\sl360\partightenfactor0 \f0\fs26 \cf2 \cb3 \expnd0\expndtw0\kerning0 \outl0\strokewidth0 \strokec2 \ }. Got my casing welded all good now
Post by arrow on Oct 2, 2014 16:39:01 GMT 1
Sorted. Had a mental block. Of course the weld is not seen.
Post by stusco on Oct 2, 2014 17:19:07 GMT 1
I've got a carbon Yamaha disk coming from Norbo
