Post by muddyfox on Sept 19, 2014 14:16:26 GMT 1
hi chaps, quick question, the stator plate, approxmitly where should the bolts be, mine are set all the way to the front, is this correct the bike is new to me! thanks and as soon as i sort this ill get some pics up! regards 81 rd350lc
Post by yamark on Sept 19, 2014 19:51:37 GMT 1
Hi qwerty, welcome to the forum. I think you are saying the stator bolts are at the end of the elongated slot? These bolts adjust the ignition timing. Normally they are not at the end of the slot. You need a dial gauge to properly check the timing marks are correct. Then you need a strobe light to check the ignition timing. Worth checking as you can knacker your pistons if the timings out.
Hope I've answered your question as I think that's what you meant.
Regards Mark
Post by muttsnuts on Sept 19, 2014 20:09:58 GMT 1
yeah, looks wrong to me, does the bike start/run?, if so, you need to be checking that timing before you ride it, static timing should be 2mm BTDC and with a strobe and the engine running at 2000 rpm the timing marks should align
HTH
whereabouts are you in case your local to somebody who could help you out if you need a hand sorting it, its only a 10 min job, but will save you an expensive blow up if its wrong
HTH
Post by muddyfox on Sept 19, 2014 20:12:50 GMT 1
yup thats them, lol i nearly got my answer cheers! still dont know if it needs moving back from full advance?the bike according to old owner was a runner rebuilt in jan and never run, he said it needed a key and the nut as he nikked it for hes other RD so my job today was to replace key and nut! i havent tried to start it wanted to check it over first
thats when i noticed the timing, where is yours set?
seems to have a rgv running gear , swinger, rgv wheels, 31k carbs with spacers, it got good comp, owner tried to mot it and it failed, not suprised forks twisted in the yokes and chain tension was like a tight rope, and not in line either,
so i want to make it safe before i start it, clean carbs, balance them check oil pump, clean tap, check fluids, thne fire it up!
regards
Post by muddyfox on Sept 19, 2014 20:19:27 GMT 1
oh im in manchester!
cheers
Post by steeley on Sept 19, 2014 21:04:44 GMT 1
hi welcome in,good site here .off the top of my head if I have got this right.the rotor on the end of the crank is loose, no nut /washer /spring washer and there is no woodruff key in the crank.so let me get this even more right in my head, you may or may not of heard this bike run. this was a mate right and you have seen it being rode around.sorry for being or seem to be negative, I have been out for a while not as young as I used to be.your best bet is to get the bits you are missing,then have some one drop a dial gauge down the l/h cylinder and set the timing up for you.should be some one on here up your way to help you out.ah just reread your last post.the logbook has the address you picked it up from .
Post by muddyfox on Sept 20, 2014 11:36:56 GMT 1
cheers for the reply, i have the bits and fitted them, rotor is tight and new spring washer and key, its just the stator plate im worried about before i fire it to check timing, i have a dial gauge !
ive backed it off a bit around 2mm, so im cleaning carbs to day and replaced the gearbox oil already
wish me luck it starts
regards
Post by muddyfox on Sept 20, 2014 11:38:20 GMT 1
any one near me fancy having a deco?
regards
Post by steeley on Sept 20, 2014 21:37:59 GMT 1
sorry mate,if I was half hour a way I would be there to give you a hand and half a laugh and a pint.must be some one close to you to give you a hand.
Post by muddyfox on Sept 20, 2014 22:54:21 GMT 1
thanks anyway dude!
regards
