daveg
ProClassic
Post by daveg on Sept 16, 2014 12:50:39 GMT 1
Hi all, Quick piece of advice please. I had my crankshaft rebuilt, and I noticed that the rhs bearing (the one with the small nipple) had spun round in the seat, making a small gouge in the seat. The new bearing equally small nipple will also rotate in the gouge made by the old one. Do you think I should add a small layer of loctite to prevent this or just let it spin 90 degrees of so until it gets jammed?
Thanks,
DaveG
Post by Delbert on Sept 16, 2014 14:01:22 GMT 1
If it was mine I would use some stud & bearing lock,, once you clamp the cases together it shouldnt go anywhere , I wouldnt let it spin & hope !
daveg
ProClassic
Post by daveg on Sept 16, 2014 15:13:57 GMT 1
Any recommendation on the stuff to use?
Post by markhoopy on Sept 16, 2014 16:31:41 GMT 1
+1 Used this to cure the same problem on my 350N .. bolted the cases together one afternoon, posted pics in my rebuild thread that evening and another member pointed out that we had put the right-hand crank oil seal in the wrong way round. Opened the cases the following day to switch the seal round and had a right b*st*rd of a job getting the crank out of the bottom case - stuck like sh*t to a blanket ..
daveg
ProClassic
Post by daveg on Sept 16, 2014 16:46:30 GMT 1
Hmmm not sure if that is good or bad, after all i may have to do it again in a years time.
Post by Yogi on Sept 16, 2014 18:42:43 GMT 1
As long as the bearing doesn't seize it shouldn't spin,I always use bearing lock anyway
Post by steeley on Sept 16, 2014 18:54:01 GMT 1
bearing fit on the outside will be ok.if you were really worried change the bearing on that end to one with a pin and make a recess in the case for the pin.
daveg
ProClassic
Post by daveg on Sept 17, 2014 10:21:38 GMT 1
I bought some loctite 641, which is supposed to be good for this application and not as hard i.e. you can dismantle again, as other stuff.
I was advised by the guy who rebuilt my crankshaft to use ONLY on one side of the crankcase otherwise impossible to split them again!
Post by spondonchris on Sept 17, 2014 15:03:32 GMT 1
We Araldited a set in years ago and they never spun again.
alexm
Post by alexm on Sept 19, 2014 13:24:43 GMT 1
Agree bearing lock
