Post by ruffneck247 on Sept 14, 2014 17:41:26 GMT 1
Hi,
I have a problem with my 350LC. If I don't turn the fuel off, the fuel flows into the left barrel causing a hydraulic lock. Anyone got any ideas why this may be happening?
Thanks Chris
Post by jessy03 on Sept 14, 2014 18:25:03 GMT 1
Sticky float valve or float height set in correct, my guess Jess
Post by huggy76 on Sept 14, 2014 18:50:49 GMT 1
+1
Post by ruffneck247 on Sept 14, 2014 19:26:12 GMT 1
Wouldn't fuel pour out of the overflow pipes if that was the issue?
Post by yamark on Sept 14, 2014 19:35:14 GMT 1
Do you know that the internal overflow tubes are clear? Add to list worn float valves, perished o ring on valve seat, dirt in fuel tank. Be careful with hydraulic lock - you can bend conrods !
Hope you get it sorted
Regards Mark
Post by ruffneck247 on Sept 14, 2014 20:02:15 GMT 1
Thanks, could it possibly be worn emulsion tube/needle? I'll get a carb service kit.
Post by steeley on Sept 14, 2014 20:04:08 GMT 1
yep get yourself a carb refurb kit ,better still get 2 and do both carbs.put the one that's not leaking in the one bag as a spare and bin the one that's leaking /no good.yes watch hydraulic lock.
Post by rich on Sept 14, 2014 20:50:48 GMT 1
I'd also fit a service kit or replacement fuel tap. Sometimes the tap can be passing fuel and it will still seep past the carb float valves causing flooding. My 250LC used to do it if it was left more than a few days between use.
Fuel flow
Sept 14, 2014 21:28:25 GMT 1
via mobile
Post by Delbert on Sept 14, 2014 21:28:25 GMT 1
I'd also fit a service kit or replacement fuel tap. Sometimes the tap can be passing fuel and it will still seep past the carb float valves causing flooding. My 250LC used to do it if it was left more than a few days between use. +1 before I fixed mine I used to turn the tap off & run it out of fuel , that way it was Ok for a few days till the carbs filled up again
alexm
Post by alexm on Sept 19, 2014 13:29:45 GMT 1
Did the carb kit work ok
