scoobysal
If it hurts, you know ya made it.
Post by scoobysal on Sept 14, 2014 17:33:03 GMT 1
Hi guys, anyone know of a manufacturer that will do these? my searches are fruitless at the moment.
Post by oldelsieboy on Sept 14, 2014 17:34:08 GMT 1
Hi guys, anyone know of a manufacturer that will do these? my searches are fruitless at the moment. www.venhill.co.ukOEB
Post by steve h on Sept 14, 2014 18:00:57 GMT 1
Post by midlifecrisisrd on Sept 15, 2014 7:58:44 GMT 1
Can you not use an lc2 throttle cable?
scoobysal
Post by scoobysal on Sept 15, 2014 11:17:13 GMT 1
Am I right in thinking or being advised that it's a three part cable and involves the oil pump? Don't know about the lc2 Steve? All this for Renthal bars, better be worth it!!!!!
Post by midlifecrisisrd on Sept 15, 2014 16:53:47 GMT 1
Am I right in thinking or being advised that it's a three part cable and involves the oil pump? Don't know about the lc2 Steve? All this for Renthal bars, better be worth it!!!!! Throttle cable is a 3 parter. Splits one for each carb and one for oil pump. I take it that you have fitted motocross renthals as the superbike ones are not much wider Lc2 YPVS throttle cable should be similar but a bit longer as used mikuni carbs and same oil pump but it has wider bars. Sure someone will know if it fits the throttle grip the same. Steve
scoobysal
Post by scoobysal on Sept 15, 2014 22:25:39 GMT 1
Thanks Steve, that's what I thought. Yes the bars are wider and higher. I will have a look and seeif it fits the same.
scoobysal
Post by scoobysal on Sept 16, 2014 10:32:15 GMT 1
So guys does anyone have a 31k ypvs throttle cable and will it fit my RD350LC, as in is it much longer than the LC standard?
daveg
ProClassic
Post by daveg on Sept 17, 2014 10:23:40 GMT 1
I made my own. Soldering iron, some nipples, and the kit purchased from Trailbits.co.uk and away it goes!
scoobysal
Post by scoobysal on Sept 23, 2014 0:01:39 GMT 1
Managed to reroute all the cables.
Post by raven13 on Sept 23, 2014 0:11:57 GMT 1
I made my own as well. have lasted 2 years of near constant use
