Post by jackjabba on Sept 14, 2014 11:30:06 GMT 1
Another clutch question, How many damper rings should there be on a YPVS clutch?
Regards Jack
Post by oldelsieboy on Sept 14, 2014 12:03:47 GMT 1
Another clutch question, How many damper rings should there be on a YPVS clutch? Regards Jack The answer can be obtained from your parts fiche, item 18. OEB
Post by stusco on Sept 14, 2014 12:15:35 GMT 1
Do people still fit the damper rings,I have them but heard they can cause clutch drag
Post by steven on Sept 14, 2014 12:29:49 GMT 1
Hi, If you ask about, some people fit them and some dont. I fitted a full set of new ones and have had no problems what so ever.
Im sure that the problem is in the adjustment of the ecentric adjuster behind the right hand side engine cover. I set mine up when I built the engine and have never been back at it since.
My own thoughts are that this adjustment has to be spot on, and you have to take into account that as these engines are 30 odd years old now and you will get a bit of play in the bush where the gear change shaft goes through the cases. I fitted an new gear change shaft and took a bit of time to make sure that the "hook" was engaging perfectly with the selctor drum, both going up and down the gears. I sat for ages making minute adjusments to the eccentric adjuster and selecting all the gears with the engine on the bench.
You can set it up to what looks like perfet, but due to small amounts of play in the gear selector shaft, when you actualy go to selcted a gear, it might not be engaging properly.
My finding were that if you get it selecting all the gears ok on the bench, all will be well once it is used in anger.
steven.
Post by jackjabba on Sept 14, 2014 13:02:54 GMT 1
Thanks OEB, I don't have a copy of the fiche.
My clutch only has the first 2 fitted.
Post by oldelsieboy on Sept 14, 2014 13:10:19 GMT 1
Thanks OEB, I don't have a copy of the fiche. There are 3 very important items all LC/YPVS owners should have; 1. Parts Fiche 2. Workshop Manual 3. Deep Pockets Download your part fiche HEREOEB
Post by jackjabba on Sept 14, 2014 13:36:29 GMT 1
Thanks OEB, I don't have a copy of the fiche. There are 3 very important items all LC/YPVS owners should have; 1. Parts Fiche 2. Workshop Manual 3. Deep Pockets Download your part fiche HEREOEB Thanks, I now have all 3, but the deep pockets are empty.
Post by Deleted on Sept 14, 2014 15:39:59 GMT 1
Well I have just learnt something here, did not know that this section existed, every bolt I have replaced with stainless I had to measure and order, if only I knew the size list beforehand it would have saved a whole lot of time
Cheers OEB
Post by muttsnuts on Sept 14, 2014 16:47:45 GMT 1
The reason some of the clutches drag is if aftermarket plates are fitted or the wrong clutch basket is fitted, some aftermarket plates are slightly thicker than the Yamaha ones which are 3mm if I remember correctly, I've had some aftermarket ones (inc heavy duty EBC) ones that have measured 3.1mm, which doesn't souund much, but times that by 7 and its 0.7mm and given the total clutch travel is approx 1.8mm to 2mm, its quiet a lot to lose, leaving the damper rings out helps.
If you fit the wrong clutch basket, then you can have issues with the stack height as well, so you need to be sure all of the right parts and clearances are present otherwise clutch drag, which also means difficult neutral selection is a high possibility.
HTH
Post by stusco on Sept 14, 2014 17:07:10 GMT 1
Mines all standard so better put them back in
Post by oldelsieboy on Sept 14, 2014 17:28:40 GMT 1
Well I have just learnt something here, did not know that this section existed, every bolt I have replaced with stainless I had to measure and order, if only I knew the size list beforehand it would have saved a whole lot of time Cheers OEB For future reference most bolts sizes can be gleaned from the part numbers. EG: 97326-06025, the last 5 digits are the screw/bolt gauge & length, 06=M6, 025=25mm long. HTH OEB
Post by Deleted on Sept 17, 2014 9:08:06 GMT 1
something els(I)e I have learned
Cheers
Post by andrew on Sept 17, 2014 22:10:47 GMT 1
There are 3 very important items all LC/YPVS owners should have; 1. Parts Fiche 2. Workshop Manual 3. Deep Pockets Download your part fiche HEREOEBWas ok until the "3. Deep Pockets" bit, then the lights went dim and the power failed lol, im sure though that I cannot be on my own when I say that this bike has taken me months to get where it is, when if I had unlimited finance and tooling then I could have probably done the same in days, but all members on a budget should take heart with this:.... I ENJOY IT!!!!!!!!!!!!!!!, to me that's what fannying about in the garage is all about
Post by Delbert on Sept 18, 2014 7:01:30 GMT 1
I fannyed about for 6 years till mine was up & running ,,, 3 years on and still fannying
Post by jackjabba on Sept 18, 2014 10:38:05 GMT 1
I am at 10 years + on my RD 500 and still not ridden it. Just keep spending the money on other things.
Going to sell my 1100 Katana next year and get it finished.
