Post by fatty on Sept 14, 2014 7:10:07 GMT 1
Hi All I have just rebuilt my clocks.. new decal faces trip knob covers etc.. There is a slot on the tacho where it looks like something has been removed, there is a pair of wires taped up, which backs up this ! What is the item and what is its function, and do i need one ?
Ta for the help Ash
Post by shane250 on Sept 14, 2014 7:43:02 GMT 1
It's the sensor for the self cancelling unit.
Post by fatty on Sept 14, 2014 8:31:58 GMT 1
Ok Thanks for the info.... What does it do. and do i need it.... as i aint got one It's the sensor for the self cancelling unit.
Post by shane250 on Sept 14, 2014 9:26:21 GMT 1
I would imagine you only need it if you want the self cancelling to work.Doesnt it go in the speedo not the Tacho?
Post by fatty on Sept 14, 2014 10:33:36 GMT 1
Your probably righr they were upside down and i was putting them back together when i niticed the little harness cut off... So looks like i need one of those then.... I would imagine you only need it if you want the self cancelling to work.Doesnt it go in the speedo not the Tacho?
Post by markhoopy on Sept 14, 2014 10:47:31 GMT 1
Your probably righr they were upside down and i was putting them back together when i niticed the little harness cut off... So looks like i need one of those then.... I would imagine you only need it if you want the self cancelling to work.Doesnt it go in the speedo not the Tacho? Not the best pic to show you, but the reed switch is over to the left ..
Post by fatty on Sept 14, 2014 20:00:08 GMT 1
Yeh i see it. are they only in the lc model or do other bikes have them ?
Post by yamark on Sept 14, 2014 20:12:16 GMT 1
A few Yamaha's from that era have them. It's called the reed switch or reed sensor but I don't know if they are interchangeable between different models, I would guess yes. The reed switch senses the distance covered and signals the self cancelling unit [located below the ignition coil].
HTH regards Mark
Post by markhoopy on Sept 14, 2014 21:10:20 GMT 1
Yeh i see it. are they only in the lc model or do other bikes have them ? The pic I used is of a 350 YPVS clock light wiring set - I would think the reed switch/sensor is the same as on the LC
Post by fatty on Sept 14, 2014 21:47:17 GMT 1
Thanks for the info fellas, al check out evil bay
