Post by LC_BOTT on Sept 13, 2014 10:48:22 GMT 1
Hi, is the difference between 250 and 350rear wheel fitments, just the rear spacer? my 350 came with 250 wheels fitted (and the 350 original wheel, but nothing else,(got sprocket carrier/brake plate etc) is this the only part I need to source?
Post by rich on Sept 13, 2014 10:53:16 GMT 1
Brake drum side spacer is the same but sprocket spacer is different. There is also a spacer inside the 350 cush drive hub that should be inside the bearing but can drop out so make sure you have it. Sprockets are also different bolt spacing and the 350 set up is a lot heavier!
Post by LC_BOTT on Sept 13, 2014 11:50:37 GMT 1
Thanks for that, will have another look and see exactly what I have, before I stick a wanted post up.
alexm
Post by alexm on Sept 19, 2014 13:27:39 GMT 1
Hope you sorted ok
