Post by kostas on Sept 9, 2014 19:33:07 GMT 1
Will soaking the chain in petrol harm it in any way?
I left mine to soak for a couple of weeks and now it has gone stiff at some links...
Kostas
Post by raider18 on Sept 9, 2014 19:41:11 GMT 1
probly fecked the '0'rings petrol will do that
Post by kostas on Sept 9, 2014 20:29:57 GMT 1
Don't even know if it is an o-ring chain?? Is there a way to tell?
Also what's the right size for the 350 ypvs F1?? 520 but how many links?
Kostas
Post by copper99 on Sept 9, 2014 21:39:53 GMT 1
After going to the time/expense of repairing that chain damage, dont skimp on a chain Kostas, just bin it...I wish id got a new one after my engine was rebuilt..
Post by kostas on Sept 9, 2014 21:58:33 GMT 1
After going to the time/expense of repairing that chain damage, dont skimp on a chain Kostas, just bin it...I wish id got a new one after my engine was rebuilt.. You are spot on there.. Can't afford damaging the engine again by a broken chain. It is just the the sprockets and chain look like new.. But I will have to bin it just to be on the safe side. Norbos shop says the chain is 106 links, is this correct? Does the have to do with how many teeth the sprockets have? Anyone knows about this? Kostas
Post by copper99 on Sept 9, 2014 23:00:45 GMT 1
My chain looked like new as well..luckily my case repair was straightforward and relatively inexpensive.
Droo Norbo a PM, he will tell you..
Post by bare on Sept 10, 2014 2:47:53 GMT 1
Will soaking the chain in petrol harm it in any way? I left mine to soak for a couple of weeks and now it has gone stiff at some links... Kostas Erm.. Yess you've completely Fecked it by doing that. Chain relies on pressure injected into the rollers, grease, during manufacture. O rings do a good job of retaining that assembly grease, consequently O ring chains live lots longer. Gasoline removes/dissolves grease = Instant Garbage.
Post by kostas on Sept 10, 2014 11:39:00 GMT 1
Will soaking the chain in petrol harm it in any way? I left mine to soak for a couple of weeks and now it has gone stiff at some links... Kostas Erm.. Yess you've completely Fecked it by doing that. Chain relies on pressure injected into the rollers, grease, during manufacture. O rings do a good job of retaining that assembly grease, consequently O ring chains live lots longer. Gasoline removes/dissolves grease = Instant Garbage. Copy that Bare. Kostas
