scoobysal
If it hurts, you know ya made it.
Post by scoobysal on Sept 8, 2014 17:45:38 GMT 1
Hi, put Renthal bars on today only to find brake lines too short. Someone has said Hel brakes but bit pricey. Anyone recommend owt else? Sal
Post by garyt on Sept 8, 2014 17:56:58 GMT 1
scoobysal
Post by scoobysal on Sept 8, 2014 17:59:19 GMT 1
Thanks Gary.
Post by steeley on Sept 8, 2014 19:26:17 GMT 1
you can buy the components and make your own.should be plenty of info on you tube.
Post by howard on Sept 8, 2014 19:38:10 GMT 1
I've used Hel a few times and found them really quick , ie next day and I also got a good discount for sending my originals for them to copy the size and banjo type .
Post by steeley on Sept 8, 2014 20:18:22 GMT 1
sorry, thought you guys here could buy the kit and measure and make your own .clutch cables ,throttle cables,power valve cables.i use to be able to make speedo and tacho cables but don't have access to that kit any more mores the pity.
Post by JonW on Sept 9, 2014 7:01:22 GMT 1
As an aside; Aussie builders remember we are not allowed screw fitting, only crimped. There was talk that DOT and other approval tags would be ok for pink/blue slips, but really the best way is to get them with ADR tags.
Post by oldelsieboy on Sept 9, 2014 7:43:57 GMT 1
Post by midlifecrisisrd on Sept 9, 2014 8:10:42 GMT 1
Agree with above, they are very good. I buy mine from there too Steve
Post by Yogi on Sept 9, 2014 9:19:31 GMT 1
Agree with above, they are very good. I buy mine from there too Steve +2
scoobysal
Post by scoobysal on Sept 9, 2014 12:30:30 GMT 1
Thankyou for your help, will have a look. Hel coming in at £89.
Post by nikfubar on Sept 9, 2014 15:27:23 GMT 1
Agree with above, they are very good. I buy mine from there too Steve +2 +3 use them on all my bikes, never had a problem Best way to work out the length of hose needed is to get some 8 or 10 mm flexible pipe, route it from the master cylinder to the caliper in the desired position, mark it then remove & measure the length you have, most of the screw on banjo's are around 25 mm long so just deduct from the overall length & chose the closest length of line above your measurement to allow a bit of slack unless it is exact.
scoobysal
Post by scoobysal on Sept 11, 2014 17:05:03 GMT 1
I used string and need three lines.
scoobysal
Post by scoobysal on Sept 12, 2014 17:47:16 GMT 1
Got all the lines today and brake fluid so tommorow I will be in the scraped knuckle gang! I did snipe an original manual tonight though on eBay!!!!!!
scoobysal
Post by scoobysal on Sept 14, 2014 16:03:04 GMT 1
Well, brake lines on after a lot of swearing, nuts and bolts on man tight so struggled to get them off. Throttle cable and clutch cable now too short.
