Post by rich on Sept 6, 2014 23:20:12 GMT 1
Anyone tried widening a pro am belly pan? I recently bought a new one for my LC but I can't get it to sit tight underneath the engine because the fat part of the Nikon downpipes hit the inside edges of the belly pan. It's also not helped by the fact that my footrest hangers are spaced out so the pipes clear the swingarm and rear wheel spindle. I tried for ages repositioning it but only way I can get it to clear the pipes it sits too low and forward and looks crap Any suggestions? I'm not too fussed about cutting it but it's rejoining it that will be more tricky. I'm thinking thin ally sheet and rivets? Could I use filler over the top? Not worried about the underneath but the front bit behind the wheel needs to look half decent.
Post by steeley on Sept 7, 2014 5:39:42 GMT 1
[img src=" i1296.photobucket.com/albums/ag2/raysteele350lc/tzr%20350%20photos/S5000923_zps85f5668e.jpg" src="http:// " alt=" "] hi, this is how I modified my tzr lower fairing which is fiberglass / grp.i cut it down the centre ,cut a couple of strips of steel these were stuck on using fiberglass matt and resin got the kit from Halfords.then I fixed some thin plywood to the outside of the fairing /small screws.then cut my fiberglass matt to size and applied it to the inside on both halves .when cured ,remove the wood or whatever you have used and see how it fits.it will need some filler on the outside to get a nice finish.the metal tags will be on the inside .line the panels up drill through the metal tags /other panel for your fixings I used dzus fasteners.hope this is of help.
