Post by marddy on Sept 4, 2014 12:20:14 GMT 1
Hi,
I am quoting Part numbers of Crank Bearings from the respective Parts Manual.
In Air-Cooled RD B Manual: Center/Inner [B6206 C3 Special] = 93306-20604 Outer Magnet side [B6305 C3 Special] = 93306-30508 Outer Clutch side [B6305 C3 Special] = 93306-30508
In RZ 48H Manual: Outer Magnet side = 93306-30510 Outer Clutch side = 93306-30531 Center/Inner side = Not mentioned
In RZ 350 N/NC/NC2 Manual: Outer Magnet side = 93306-30564 Outer Clutch side = 93306-30549 Center/Inner side = Not mentioned
In 31K Manual: Outer Magnet side = 93306-30510 Outer Clutch side = 93306-30531 Center/Inner side = Not mentioned
Need info/clarity:
1] I thought Air-cooled RD Outer Bearings [Magnet side] can also be used as Inner Bearings in the RZ. 2] Why are the Part numbers of Crank Bearings of 48H & 31K different from 350 N/NC/NC2 models? 3] All three YPVS Manuals does not mention about Center/Inner Bearings. Why?
I am eager to know as I have to procure Crank Bearings for my 2 AC RDs and 1 RZ.
Post by chippy348 on Sept 4, 2014 23:26:21 GMT 1
1] I thought Air-cooled RD Outer Bearings [Magnet side] can also be used as Inner Bearings in the RZ. Correct they are the same 2] Why are the Part numbers of Crank Bearings of 48H & 31K different from 350 N/NC/NC2 models? Don't know why but they are the same bearing size. 3] All three YPVS Manuals does not mention about Center/Inner Bearings. Why? I believe they only offer a complete center section IE 2 inner webs, 2 center bearings all pressed onto the center shaft so this is why they don't list them as a separate part.
Post by Tone on Sept 5, 2014 6:26:02 GMT 1
In answer to question 2) I seem to remember reading that on the later N2 and F2 models they increased the clearance between the balls/races of the crank bearings, so probably why the change in part numbers.
Tone
Post by greasemeup on Sept 5, 2014 7:32:05 GMT 1
Bigger Balls then? Sent from my iPhone using Tapatalk
Post by marddy on Sept 13, 2014 13:37:51 GMT 1
Bigger Balls then? Sent from my iPhone using Tapatalk No, this is not the case.
