Post by Shytalk on Sept 3, 2014 19:50:38 GMT 1
As title, I'm after a set of dog bones made for my Fazer can any one recommend anyone/where or know where to get some off the shelf please?
Post by cb250g5 on Sept 3, 2014 20:14:06 GMT 1
Post by midlifecrisisrd on Sept 3, 2014 20:36:20 GMT 1
As title, I'm after a set of dog bones made for my Fazer can any one recommend anyone/where or know where to get some off the shelf please? Ebay usually has them. 600 or 1000? Maxton do them as well but not the cheapest. Got a set on mine, they are metisse or something like that but fitted a Maxton shock and it but now on tip toes and wheel touches the ground on the centre stand so reckon the shock is longer too so will probably go back to standard bones Steve
Post by Shytalk on Sept 3, 2014 22:14:55 GMT 1
As title, I'm after a set of dog bones made for my Fazer can any one recommend anyone/where or know where to get some off the shelf please? Ebay usually has them. 600 or 1000? Maxton do them as well but not the cheapest. Got a set on mine, they are metisse or something like that but fitted a Maxton shock and it but now on tip toes and wheel touches the ground on the centre stand so reckon the shock is longer too so will probably go back to standard bones Steve Its for a 600 Steve, I've got an R6 shock fitted but the supplied dog bones are 3mm too thick and the self locking nuts don't bite on the bolt thread. This is what I'm after - Bolt holes 12.05mm in diameter, with their centres drilled 127mm apart.
Post by soccersmyth on Sept 3, 2014 22:58:35 GMT 1
I have a set of dog bones to raise the height of the back end of a 600 fazer.
I'll measure them at the weekend to see if they'll do your job.
Post by Shytalk on Sept 4, 2014 8:09:53 GMT 1
I have a set of dog bones to raise the height of the back end of a 600 fazer. I'll measure them at the weekend to see if they'll do your job. That would be good - thanks.
Post by midlifecrisisrd on Sept 4, 2014 11:20:18 GMT 1
If the bolt is 3 mm too short could you not get 1.5mm milled off the outer faces of the dog bones where the bolts sit.
Either that or sounds like the bolt is m12 so could you not get a longer bolt?
Post by Shytalk on Sept 5, 2014 17:01:18 GMT 1
If the bolt is 3 mm too short could you not get 1.5mm milled off the outer faces of the dog bones where the bolts sit. Either that or sounds like the bolt is m12 so could you not get a longer bolt? Steve Easier said than done with the milling - but yes that was one thought, and I could also go with a longer bolt but I like to use the standard bolts where possible, as they were designed for the job, I think I have a set of standard thickness bones on the way so will see, but thanks for the input.
Post by soccersmyth on Sept 6, 2014 20:00:10 GMT 1
Can you decipher them measurements in millimetres if these are any use for your job
Post by greasemeup on Sept 6, 2014 20:05:18 GMT 1
To get centres measure hole to hole, left side to left side..
Sent from my iPhone using Tapatalk
Post by Shytalk on Sept 10, 2014 18:55:41 GMT 1
Can you decipher them measurements in millimetres if these are any use for your job Too long unfortunately but many thanks for taking the trouble to dig them out and post the pictures, much appreciated.
